Sump Plug Washer Size? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-17-2010, 04:50 PM   #1 (permalink)
Favourite Bike: T595
MarkShelley's Avatar
Other Motorcycle: Sprint 900
Extra Motorcycle: XTZ660, BMW1100GS
Anyone know the spec for this. I want to buy a supply from somewhere other than a Triumph dealer. They are stupid prices if bought individually!
MarkShelley is offline   Reply With Quote
Old 02-19-2010, 08:37 PM   #2 (permalink)
rickster's Avatar
My best guess is 14mm, but that is just a guess. You might measure it at the next oil change and get them in bulk at an auto parts store.
"The older I get, the faster I was".
rickster is offline   Reply With Quote
Old 02-21-2010, 07:11 AM   #3 (permalink)
Favourite Bike: My '04 Sprint-ona
RexxyPup's Avatar
Other Motorcycle: Want a 675
Extra Motorcycle: I wish!
Dimensions
Just measured my spare aluminium sump washer..
Outside diameter 22mm
Inside Diameter 15mm
Thickness 2mm
I only have two, which I alternate. If you have a plumbers blow torch for silver soldering pipe joints then you can use it to anneal your old one. Tightening your sump plug deforms the aluminium washer slightly and work hardens it so that if you re-use it, it won't deform and therefore not make a seal. Annealing removes the work hardening.
What I do is take the old one off and replace it with the new. Lay the old washer on a piece of asbestos cloth (you use it in plumbing to protect the stuff around the pipe being soldered) and run the blow torch flame gently back and forth across the washer until you see a slight orange glow in the metal following the trailing edge of the flame and then stop. You've now annealed your washer ready for the next time.
Rexx
WARNING:! Low flying Sprint-ona ahead!
Old Albums
New Albums
RexxyPup is offline   Reply With Quote
Old 02-21-2010, 11:26 AM   #4 (permalink)
Thickness 2mm
Rexx
Blimey. You are not Scottish by any chance are you?
Old 02-24-2010, 08:05 PM   #5 (permalink)
RexxyPup's Avatar
Nope, but....
Anything spent elsewhere is money not available for fuel and visible farkles!!! LOL
Anyway need to save money on the washer to pay for the fairing fasteners!
Rexx
Old Albums
New Albums
Sump Plug Allen Key Size ivincent T3 Sport / Touring Forum 3 09-22-2008 09:12 PM
Sump Plug Sealing Washer ajfisher Twins Technical Talk 4 05-18-2008 09:24 PM
sump washer BeastInBlack Twins Technical Talk 2 07-19-2007 09:45 AM
Sump plug washer T100 or Trident danbike Maintenance & Workshop Talk 1 03-12-2006 09:47 AM
Oil sump sealing washer thumper723 Maintenance & Workshop Talk 0 09-28-2004 03:23 PM
