01' 955I Suspension Set Up Question - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports Motorcycle.com Classifieds!Ontario TourismMotorcycle.com
Old 11-18-2009, 11:59 AM   #1 (permalink)
Rafo's Avatar
Have a 01' 955i. Purchased it used about a year ago. I love the bike but I'm not sure the suspension is set up correctly.
I have the factory service manual but it does not show the factory settings for the rear sag. Does anyone know what that setting is?
Also, I noticed that the forks are pulled through about 11mm above the triple clamp. It shows these as being set flush in the service manual. I can only assume that they were raised to drop the front end to make it turn a bit faster into corners. This may have been done to compensate for the rear srping, that the previous owner set in the softest position, which I would guess would lower the rear end.
Any ideas? The bike still seems to turn a bit slow for me and compared to my ZRX1200R.
Ray.
Ray F.
01' Daytona 955i
Rafo is offline   Reply With Quote
Old 11-18-2009, 03:38 PM   #2 (permalink)
Newbie
Suspension on 955i
It's going to be hard to set the sag to proper numbers unless you weight about 50lbs. The springs front and rear are too soft. That said, figure out where they are and then work on it. What do you weight?
With age, the numbers in the manual will not be correct likely due to wear of springs plus the wear on the damping adjusters so again you can't go by the book.
I would suggest starting out with a new set of springs, a fork rebuild and a revalve of both ends using a gold valve in the rear. I do not recommend a gold valve in front.
As for the forks being pulled up, it does improve the geometry all things being equal....but they are not. Hard to make it handle quicker without FIRST getting the springs right. Your forks are pulled through too much though. Set them about 5-8 MM pull through.
Art
Ray.
wsmc888 is offline   Reply With Quote
955i suspension raptor001 Daytona Deliberations 5 04-30-2009 08:57 AM
'05 955i SUSPENSION UPGRADES? Brooksie Daytona Deliberations 6 10-05-2006 07:57 PM
'05 955i SUSPENSION TIPS? Brooksie Daytona Deliberations 2 09-03-2006 08:24 PM
Daytona 955i suspension set up ustt Maintenance & Workshop Talk 2 05-02-2006 02:43 PM
955i Suspension Article in MCN ptjs1 Daytona Deliberations 5 04-13-2006 03:46 PM
