I have another problem with my 955i - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comOntario TourismSportbikeTrackGearNew BonnevilleHonda Powersports
Old 11-13-2009, 01:55 PM   #1 (permalink)
Favourite Bike: Daytona 955i
Other Motorcycle: Honda Sabre 1100
I was riding along when I hit a bump in the road and it caused the engine light to come on and the bike to stall for a second and then go right back off and continue running normally. Now, it is happening more frequently and all this started after I put full injection cleaner in it to clean the throttle bodies up after having an oil leak from the stator. Any kind of help will be helpful because I am trying to sell the bike.
Thanks
hammbone930 is offline   Reply With Quote
Old 11-13-2009, 02:55 PM   #2 (permalink)
DEcosse's Avatar
Irrelevant to the FI cleaner or generally to your previous problems
I say generally - did you ever get your seat issues sorted out? You are obviously shorting something out (or disconnecting) when you go over a bump.
Is the battery strapped down?
Are the battery terminals tight?
Does the positive terminal lead have its red rubber cover over it?
T'Rat.net BOTM November 2009
Old 11-14-2009, 01:32 AM   #3 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
hammbone930, The battery connections are my first choice also. They really can become loose over time. There should also be a hard plastic strap over the battery.
As far as the those seat clamps go (if you haven't installed them), they install into slots in the seat and bolt down to rivlets in the sub frame. Ten to one, the person who installed your battery possibly has yours somewhere in his work area collecting dust.
Let me know if you need any pics.
Brad
Old 11-16-2009, 12:27 PM   #4 (permalink)
The seat has been sorted out with velcro.
The battery is not strapped down.
The positive terminal screw was a little loose.
The red rubber cover IS intact.
I will test drive asap and get back with you to see if the screw being loose is the problem.......
Old 11-17-2009, 04:14 PM   #5 (permalink)
Favourite Bike: daytona 955i 1999
ST3V0's Avatar
Other Motorcycle: 2004 FZ6
Extra Motorcycle: VFR75F
I once had something like that happed but it was my fault.
i was riding along and my key fob (alarm) was twisted so i gave it a shake and the engine light came on and it stalled well kind off
like it was out of gear i could rev it but no power.
I pulled over turned off and started it up again all seemed fine.
all because i moved the Key
ST3V0 is offline   Reply With Quote
Old 11-23-2009, 10:03 PM   #6 (permalink)
Favourite Bike: Soon-to-be Daytona 955i
neomaximus's Avatar
I had the same problem in my car before, definitely sounds like a short somewhere.
I had it happen while I was going 70+ on the freeway; I got a huge jerk, rpms dropped to ~1k and then back up to where they were originally at that speed, all lights coming on for that half of second.
Turned out the shop I had replace my rear main seal, the day before, had taken the cap off of my battery terminal, and it was barely making contact with the hood when I hit a bump.
Good luck.
neomaximus is offline   Reply With Quote
So I just fixed my 955i wiring harness problem and now my 675's got the same problem. jrelloway Daytona675 Forum 21 12-07-2008 07:44 PM
Help 955i brake problem? Tomsk Maintenance & Workshop Talk 2 03-04-2007 08:06 AM
955i problem buggyto Daytona Deliberations 4 01-15-2007 09:18 PM
98 955i - Problem Aeras? bribassguy Daytona Deliberations 2 01-09-2007 11:52 PM
major 955i problem need help! Daytona Deliberations 5 04-02-2004 05:30 PM
