Bought 2002 955i, have questions.
Hey everyone, Im new here. I got this 02 Daytona 955i and I need some help repairing a few things.
The bike runs, shifts, and rides straight. It was dumped at low speed on dirt. The right side fairing is scratched and cracked but the cases, tank, etc.. are all good. Are there things I should re torque or straighten in the frame or headstock? Should I balance and align the tires?
The rear brake wasnt working when I got it but I vacuum bled both brakes and they work good now. I noticed it takes a few seconds to start the bike when cold like it is hesitating. When revving the engine the headlights dim a little. The speedo reads 0 MPH but RPM works. Not sure about ODO. Should I get a new battery?
The bike was sitting while the last owner was in the military. When I flushed the radiator, it was bad. Real bad. There was some rust, dirt, grime, etc... Im thinking about getting the radiator acid dipped to take out the corrosion and rust. Is this a good idea?
The motor oil looked decent but I am going to change it and the filter along with other things the bike needs.
I need a way to lift the wheels off the ground so I can adjust the chain. The exhaust is in the way and there is no frame supporting the lower part of the engine. Is there a way I can jack up the bike without spending a fortune on stands?
I really need help refreshing this bike and get it road worthy. Are there other things I should do while I am working on the bike for the winter and while it is apart?
