EPG MotoBritish Motorcycle GearMotorcycle.comTriumphPerformanceUSATriumph Detroit
Old 11-02-2009, 10:58 AM   #1 (permalink)
Newbie
Favourite Bike: 04 daytona 955i
Other Motorcycle: 01 suzuki sv650s
Extra Motorcycle: 93 H-D xlh883h/1340
04 daytona lowering links?
anyone know of lowering links or fork straps for the 04 955i daytona? i cant seem to find them anywhere.
blackEdouT955i is offline   Reply With Quote
Old 11-02-2009, 11:04 AM   #2 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
Extra Motorcycle: SV650S
http://www.whaccessories.com/TriumphAccessories.htm
T'Rat.net BOTM November 2009
Suzuki TL1000S................Suzuki SV650S.............Triumph Daytona
http://www.triumphrat.net/image.php?type=sigpic&userid=2434&dateline=1225242  733
Old 11-03-2009, 07:24 AM   #3 (permalink)
Favourite Bike: 04 Triumph Speedtona 955i
Other Motorcycle: 09 Buell Ulysses XT
Extra Motorcycle: 85 Moto Guzzi Lemans 1000
Hi Decosse:
I've often thought of getting a lowering kit... the reference you provided sez the kit lowers the rear by 40mm... which could be a good thing for me since I am somewhat vertically challenged.... can just get the ball of my foot barely down on my Daytona (04)....
but... what I wonder about or am concerned with... is don't you then have to lower the forks through the triple trees? and doesn't that change the rake and trail of the front end? Any experience here? Any advice?
thanks,
Mike
MQracing is offline   Reply With Quote
Old 11-03-2009, 09:25 AM   #4 (permalink)
Newbie
Talking rake and trail
Originally Posted by MQracing View Post
Hi Decosse:
thanks,
Mike
yes u do have to lower the forks but not through the trip tree, they make little straps that you simply compress the forks with, atleast thats how it was on all my other bikes but no it doesnt mess with the rake and trail....just makes it look low slung and pissed off
Old 11-03-2009, 12:45 PM   #5 (permalink)
DEcosse's Avatar
... don't you then have to lower the forks through the triple trees? and doesn't that change the rake and trail of the front end? ....
If you DON'T adjust the front correspondingly then you WILL have changed the rake and thus the trail; lowering the rear end will change the rake angle - it will be less acute; this means the trail will be longer and the bike will be slower to steer.
So in order to keep the geometry the same, you need to lower the front by same amount to retain the same head angle (rake) as previously
Note that you don't actually 'lower' them in the trees, you raise them (raising the forks through the triples, or conversely lowering the triples on the forks )
The result is that your bike's geometry will be approximately the same - same rake & trail, a little shorter wheelbase and lower C of G.
The downside is your ground clearance during cornering
Here's an article I authored that helps explains the relationship between rake & trail
That was written from a perspective of the rear end remaining constant and how changing the rake angle affects things.
Here you would be starting by changing the rake angle when you lower the rear, then 'recovering' it by adjusting the fork height accordingly
Originally Posted by blackEdouT955i View Post
....yes u do have to lower the forks but not through the trip tree, they make little straps that you simply compress the forks with...
I'm sorry man - that is simply most ridiculous thing I have ever heard
....but no it doesnt mess with the rake and trail....
Regardless of how you raise or lower the bike it WILL mess with the rake and hence the trail.
Old 11-04-2009, 12:07 PM   #6 (permalink)
DEcosse's Avatar
One absolutely free method you can use to lower the rear end on the SSSA bikes, is just to rotate the eccentric hub by 180 degrees.
Old 11-09-2009, 09:02 PM   #7 (permalink)
Favourite Bike: D955i CE
Erickex's Avatar
Love the idea of the free method DEcosse. Is it a significant amount it lowers the rear by?
I take it I will have to remove a link or two.
Erickex is offline   Reply With Quote
Old 11-10-2009, 01:39 AM   #8 (permalink)
DEcosse's Avatar
Originally Posted by Erickex View Post
... I take it I will have to remove a link or two.
Shouldn't have to change chain length at all (unless you want to try & get the absolute minimum height)
Let's say that the axle is at the 180 deg level (measured fore-aft on a line through the center of the swing arm from pivot to hub): rotating eccentric in one direction will put the axle above the horizontal center line of the swing-arm, while the opposite direction will place it below - but the resultant tension on the chain will be the same whether rotated plus or minus by same angle off 180.
Note that you will likely have to shorten your side-stand if you go this route!
Also make sure your rear pre-load is set correctly and not overly stiff - if you don't have adequate sag for your weight, the bike will sit artificially higher than even spec intent.
Old 11-10-2009, 08:25 AM   #9 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Extra Motorcycle: '03 RC51 & '02 D955i
blackEdouT955i, The straps you speak of are solely used in drag racing, including magic mile events to limit the amount of front wheel travel. This in turn limits the amount of energy the front springs exerts, helping to keep the front wheel closer to the ground.
In any other riding application this modification is detrimental and possibly dangerous.
Brad
Lowering Links SSLFG Street Triple Forum 15 03-11-2010 12:53 AM
Lowering links Okie 675 Daytona675 Forum 8 04-28-2009 07:49 PM
Tail tidies & lowering links BradleyJ Street Triple Forum 4 01-28-2008 03:36 PM
Lowering a TT600 - lowering links? Natron037 Triumph SuperSports 7 06-07-2007 05:20 AM
Daytona 650 Lowering Links?? Jeffr259 Triumph SuperSports 0 02-01-2006 08:50 AM
