Battery problems. - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Ontario TourismNew BonnevilleSportbikeTrackGearMotorcycle.com Classifieds!
Old 10-29-2009, 06:58 PM   #1 (permalink)
roggie955i's Avatar
Battery problems.
2002 955i. i was out riding and it started freaking out. lights going dim and the cluster was going crazy. it only did this at and idle when i was cruising it was fine. well i stopped at a stop light and it just died. battery completly dead. wouldnt even light up the cluster with the key on. so i took it to my work and put it on the charger for about 45 min. then tested it. it said good battery with 215cca. so i put it back on till it said complete charge. took it home back in the bike. started once with a little struggle. let it run for about 20 min. shut it off. came back to leave for a ride and it almost started then completely died again. now wont do anything. battery is completely dead again. i played with the connections and nothing. and DEcosse after i charged it i just took it home and cranked it, no riding. sorry so long.
roggie955i is offline   Reply With Quote
Old 10-29-2009, 07:17 PM   #2 (permalink)
DEcosse's Avatar
Originally Posted by roggie955i View Post
2002 955i. i was out riding and it started freaking out. lights going dim and the cluster was going crazy. it only did this at and idle when i was cruising it was fine. well i stopped at a stop light and it just died. battery completly dead. ....
That is indicative that you have a charging failure - the symptoms describe exactly what happens - the dash starts going goofy and cutting off. Then the bike ends up dieing when you have drained the battery beyond the point of sustaining running.
You may have either R/R or Stator failure unfortunately - I would say to check fuse 2 first, but since you said it was worse at idle, then most likely you were getting something out of it, which more likely indicates one of the phases is down rather than fuse blown.
Go through the diagnostic guide in the S3 forum stickies to determine whether R/R or stator - or both!
Good Luck!!!
T'Rat.net BOTM November 2009
Old 10-29-2009, 07:22 PM   #3 (permalink)
roggie955i's Avatar
DEcosse thank you. what is r/r though? how expensive would a stator be? is there any way to test it or is that what the guide in the s3 is for? where is the s3 forum your talkin about lol. sorry.
Old 10-29-2009, 07:37 PM   #4 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
roggie955i, R/R is the regulator/rectifier.
Look at the diagnostic guide, DEcosse, alluded to for testing. You'll need a multimeter and also remove the tail fairing. You'll need to charge your battery prior to testing because you'll run the engine briefly without a charging circuit during the test.
Brad
Old 10-29-2009, 07:43 PM   #5 (permalink)
DEcosse's Avatar
http://www.triumphrat.net/speed-trip...r-upgrade.html
You can get through quite a few of the tests while your battery is re-charging.
If you need a stator, you can get one from http://www.ricksmotorsportelectrics.com - about $150 or so.
Do the diagnostics before you fear the worst!
Battery problems...... The_cat Maintenance & Workshop Talk 1 08-25-2009 07:21 PM
D12 Battery Problems spellbinder Daytona Deliberations 4 04-11-2009 10:33 AM
Battery Problems Newby Daytona Deliberations 11 08-30-2007 12:49 AM
Battery Problems - HELP! wongl10 Twins Technical Talk 8 08-20-2007 04:18 PM
Battery problems zippythehog Maintenance & Workshop Talk 4 09-14-2006 02:43 PM
