The bike did run great about 4 months ago i bought it and put the tank and other parts my buddy broke up after he wrecked it.I bought the bike from a friend of mine by the way thats how i know it ran good. It would not fire up so i checked the feed to the pump and i had power to prime the system so i pulled the tank off and got the pump out and ran staight power to it and nothing EVEN after beating on it a while thimking maybe it was stuck. I did find a pump from another triumph same pump as a tt600 i think, it is the same size. A buddy had it in his his shop so it was free put it in and it fired up i hope it is putting out the same flow rate and pressure. It ran good so im thinking it ok. Thanks for the help though im sure i will need more at some point as i finish putting the rest back together if you know if the pumps are diffrent please let me know. Thanks again
