triple clamp stem's diameter - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-17-2009, 03:48 AM   #1 (permalink)
Favourite Bike: 2001 Daytona 955i
Can anyone tell me the diameter of the stem that connects the upper and lower triple clamps together? The one that goes through the frame too! Thanks!
timwu is offline   Reply With Quote
Old 10-17-2009, 04:15 AM   #2 (permalink)
DEcosse's Avatar
Bottom bearing is 30/55/17
Top bearing is 25/52/15.
i.e. stem diameter is 30mm at the bottom, 25mm at the top
Steering head is 55mm at the bottom, 52mm at the head
What are you trying to fit?
T'Rat.net BOTM November 2009
Old 10-17-2009, 04:15 AM   #3 (permalink)
DEcosse's Avatar
Steering head is 55mm at the bottom, 52mm at the top of head
Old 10-17-2009, 04:28 AM   #4 (permalink)
Seeing if the whole front end of a 675 can fit into the hole on the frame for the 955s. I just read that the stem diameter on a 675 is 50mm, so i was wondering if it could easily be switched over so I don't need a custom triple clamp.
Old 10-17-2009, 11:47 AM   #5 (permalink)
DEcosse's Avatar
Nah - top & bottom bearings are 30/55/17 on the 675 - same as most Suzukis too, as well as the 1050 S3.
There is a special bearing available that will fit the 675 stem and top of your frame - bottom is same size already.
That part is easy enough.
You can't use either of your own triple clamps so you need to hope the 675 will work with your steering head - might be possible but you don't know till you try.
It's the ignition that causes interference typically.
But recognize you have other things to think about.
Can you use your own wheel?
Probably not - has 25mm axle but the 675 has 20mm axle
- diameter of 675 rotors is smaller at 310mm;
spacing between rotors may be different so you would need to check on what the 675 spacing is;
then you have to accommodate new axle spacers and moreso speedo drive- which is not trivial
on the 675 wheel you have no speedo drive capability.
Converting to electronic drive speedo gives you more options.
Steering stop is another potential problem
It is going to be expensive - if you can even find a complete set of 675 forks
You would need
Forks
Triples (top & bottom)
Axle
Wheel with Rotors
Calipers
Clip-ons
Fender
Steering head bearings
Then you still need to work out speedo and steering stop
Triple Clamp and ignition---Help posse Speed Triple Forum 9 04-24-2009 05:39 PM
95 Triple Bar Diameter/Replacement Q's bcutlerj Speed Triple Forum 0 08-13-2007 05:55 PM
WTB 1050 S3 top triple clamp w00ht Speed Triple Forum 3 08-05-2007 09:40 PM
Removing top triple clamp? dazco Twins Technical Talk 2 12-14-2006 07:19 PM
Thruxton triple clamp RandyDTFR Maintenance & Workshop Talk 1 11-30-2006 08:37 AM
