Need help with 97 T595! (Altinator?) - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismNew Bonneville
Old 10-17-2009, 12:49 AM   #1 (permalink)
Favourite Bike: 1997 t595
Aceman_831's Avatar
Hello fellow triumph riders =]
I have came across a problem. My bike died while i was riding. I had to hitch a ride with my GF to take my battery to a local motorcycle store, they charged it for me. I then installed the battery on my bike and rode it to the store to see what was wrong. My friend, whose the mechanic at the store, said that my alltinator blew out and that it wasnt charging the battery as i rode it. He hooked up a device that checked the volts that went through from having the engine on and revving the throttle... He diagnosed that it wasnt charging the battery.
He mentioned something about the stater regulator or something like that needs to be changed.
Can anyone elaborate on this problem? hints or ideas and suggestions??
The bike is currently at my GF's house because i cannot ride any further without the risk of it dying on me again.
Aceman_831 is offline   Reply With Quote
Old 10-17-2009, 01:49 AM   #2 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Aceman_831, Welcome to the forum. Would you please put the model of your bike into your profile? It'll help us in the future.
The '97 T595 uses an automotive style alternator with an internal voltage regulator. An automotive supply store may be able to test your alternator and regulator/rectifier. Bike Bandit shows a R/R, but there maybe less expensive alternatives.
Brad
Old 10-17-2009, 03:27 AM   #3 (permalink)
DEcosse's Avatar
First off, check fuse #7 in your fuse panel under the rider seat.
Could be as simple as that.
That will be the only 40A fuse that is in there.
T'Rat.net BOTM November 2009
Old 10-17-2009, 10:09 AM   #4 (permalink)
Aceman_831's Avatar
Thanks guys, i will now complete my profile with my bike info for future references.
Old 10-18-2009, 01:22 PM   #5 (permalink)
Favourite Bike: '98 Daytona
Wally's Avatar
Other Motorcycle: '64 T120 in pieces
I'll second that, got bitten by the same and thought my alternator was dead.
Wally is offline   Reply With Quote
Old 10-19-2009, 02:40 PM   #6 (permalink)
Aceman_831's Avatar
Ive come across yet what seems to be a an even bigger problem. I opened the fuse box and have discovered that my 40 fuse was melted. Since i had an extra 40 fuse, i replaced it.
Here comes the next problem...
when i turned on the ignition and tried starting it, i heard a click, similar to that of when a spark makes a sound. after that sound, nothing turns on anymore. so when i turn the ignition, my hud shows nothing. so i have diagnosed that it is definately an electrical problem. what do i do now??
i have read something in another forum (i believe) that there was a recall on t595 bikes for their electrical malfunctions... And someone had mentioned something about a wire being melted and this person had replaced that wire but had wired it directly to the battery to solve their problem...
Can anyone give me ideas of what to do next? besides taking it to a shop of course lmao, id like to try and fix it myself =]
Old 10-19-2009, 05:36 PM   #7 (permalink)
Aceman_831's Avatar
hmmm, ran another test. consisted of jumping the bike with my car battery (the car was of course off duh!) lol and everything came back on. I managed to start the bike using the jump method after a couple of tries!!!! but the real test was to turn the bike off and try again.... no luck.... lol, so im not sure if the battery(bike battery) does play a part in this situation since the bike was gettin jumped from my car battery??
quick question: would it have made a difference if i had a new battery in my bike?
The motor store said my battery was fine, but i have my doubts with it.
$74 bucks for a new battery. tempting to go out and get one really quick.... any suggestions?
Old 10-19-2009, 06:42 PM   #8 (permalink)
DEcosse's Avatar
If it started off jumper cables and not without, definitely the battery
Since your battery was not being charged with that fuse blown, re-charge your battery and it should be OK
Otherwise get a new battery if it won't recover after charging.
Use the 2A max charge rate when charging a motorcycle battery.
Old 11-17-2009, 01:43 PM   #9 (permalink)
Aceman_831's Avatar
solved my problem =] it was the battery!!!
i learned more about batteries through this experience.
The battery wasnt keeping charge because the electrolyte levels had been low (when i bought it) and low for too long. This damaged the plates that were in the battery. I did manage to fill the level to where it was supposed to be when i bought the bike but i guess it was too late. definately a dead battery waiting to happen.
So i bought a new battery and installed it and it is doing great =] i ran tests on it and concluded that definately my alternator was fine =]
woooh, lucky me heheh
thanks everyone for your help, this post now solved =]
T595 net Stampy Speed Triple Forum 6 12-14-2006 03:54 PM
T595 paulwillwin T3 Sport / Touring Forum 1 10-10-2006 07:07 PM
t595 endlessvend Daytona Deliberations 1 09-11-2006 09:15 AM
t595 itchin Speed Triple Forum 0 08-29-2006 08:58 PM
T595? PeterB Daytona Deliberations 6 08-27-2005 01:20 AM
