Oil Leak, Gear Shifter, 2000 daytona 955i - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Honda PowersportsMotorcycle.comOntario Tourism
Old 10-16-2009, 04:09 PM   #1 (permalink)
Newbie
Favourite Bike: 2000 Daytona 955i
Does anybody know if you can change that oil seal without having to split the cases? The manual I have (not the triumph manual) suggests that some of the shifter parts can be gotten to by going through the oil pan etc. Any info would be greatly appreciated. Thanks
rjiv19 is offline   Reply With Quote
Old 10-16-2009, 11:47 PM   #2 (permalink)
DEcosse's Avatar
Welcome rjiv19
Is it the one with the gear pedal linkage or the one that carries the selector forks?
Are you sure it is the gear shaft seal that is leaking?
On the 97-01 engines it is not uncommon for the casings to leak through the side-stand mounting bolt-holes. Seriously! Check that out to see if that is really your source.
T'Rat.net BOTM November 2009
Old 10-18-2009, 09:39 AM   #3 (permalink)
Newbie
rjiv19
Thanks for responding. The specific oil seal is called the gearbox lever oil seal(according to bike bandit). The circlip and thrust washer are on the outside of engine case, on the inside is the oil seal and needle bearing which are fitted around the gearchange shaft assembly.
Old 10-19-2009, 02:37 PM   #4 (permalink)
Favourite Bike: T140 ES
triday12's Avatar
Other Motorcycle: 2010 Speed Triple SE
Extra Motorcycle: '82 T140 ES
Hi
Had mine changed when serviced, and was charged no extra labour as it was done so quick !!!
Oil seal was cheap too
triday12 is offline   Reply With Quote
aftermarket mirrors - 2000 Daytona 955i matress Daytona Deliberations 12 08-18-2009 04:44 PM
small Oil leak under gear shifter nagibe Twins Technical Talk 16 05-20-2009 01:52 PM
Shifter on an 03 Daytona 955i ga_skyline_rydr Daytona Deliberations 5 05-23-2008 11:07 PM
2000 Daytona 955i aftermarket parts? Shadez Daytona Deliberations 4 05-21-2006 01:48 PM
Gp shifter or reverse shifter for t595 or 955i a82383 Daytona Deliberations 6 05-09-2006 01:24 PM
