ongoing turn signal installation - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-16-2009, 09:33 AM   #1 (permalink)
Favourite Bike: '05 Daytona 955i
Other Motorcycle: '04 Aprilia Futura
Extra Motorcycle: '80 Suzuki GS1000e
I'm installing a complete set of turn signals on to my Super III, which were absent from the last owner. I've put on three Buell signals, as recommended by another forum poster, and I'll get the fourth one in today. So far, the signals are not working. I know the lights work, from hooking them directly to feed. I hear the flasher click once, so I know power is reaching the relay.
Could it be that I need the final fourth signal installed to complete the circuit, in order to provide the relay with a complete load in order to function? If that's not it, I'm thinking I need a new flasher. Since Triumph charges...GULP!...78 bucks for a new flasher (I'm not joking), is there any reason I can't use some mongrel flasher, so long as it operates on 12 volts, 10 amps, and accommodates the same 3-prong connector?
throbenotoid is offline   Reply With Quote
Old 10-16-2009, 03:13 PM   #2 (permalink)
DEcosse's Avatar
These Buell signals are LED, yes?
This one should work
http://www.superbrightleds.com/cgi-b...uct=CAR#FL-889 - select CF13GL-02 from pull-down menu.
I'm not intimate with the wiring on the T3, but you will most likely also need to re-configure your wiring to the display indicator lamp
See this post for details.
T'Rat.net BOTM November 2009
Old 10-16-2009, 05:50 PM   #3 (permalink)
Actually, the Buell lights use regular bulbs. I went to the AutoZone and bought a universal, 3-prong flasher for ten bucks. The blinkers work but they flash quickly, which tells me this flasher relay is meant for higher wattage bulbs for a bigger load. Come to find the Buell guy can sell me a Buell flasher that will work just fine, also for ten bucks. Now what does that tell you about the Triumph company? Is this how they reward customer loyalty?
Turn Signal Daytona Deliberations 4 10-11-2010 02:35 PM
Signal minder installation question(s) Ready to Ride Twins Technical Talk 14 02-14-2010 10:23 AM
ongoing turn signal installation throbenotoid T3 Sport / Touring Forum 5 10-16-2009 05:53 PM
Right turn signal out raff Twins Technical Talk 10 05-25-2007 10:33 AM
