Electrical Fault - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda PowersportsMotorcycle.com
Old 10-15-2009, 11:02 AM   #1 (permalink)
Favourite Bike: Daytona 900
freddie136's Avatar
Other Motorcycle: Matchless G11 [1958]
Electrical Fault
Hi, I am new to the site so i hope you don't mind me jumping straight in with a problem, I have a 1995 Dayton 900,there is an electric fault on the bike,When i turn the ignition key in the lock, the Red ignition light comes on but the Green Neutral light does NOT come on,and the engine will not start or turn over, but if i lift the gear lever a bit with my foot without putting it in gear the green neutral light comes on and the engine will start,as soon as i let the gear lever return to it's normal neutral position or try to put it in gear the engine just stops and only the red ignition light is showing again. I would appreciate any help with this problem,thanks in advance. Fred
freddie136 is offline   Reply With Quote
Old 10-15-2009, 12:02 PM   #2 (permalink)
Favourite Bike: 1999 Triumph Speedtona
Neutral sensor sounds like its not working. Is the kick stand down when the engine cuts out when you let go of the shift lever?
sachem87184 is offline   Reply With Quote
Old 10-15-2009, 12:15 PM   #3 (permalink)
Favourite Bike: harley xl1200r widearse
kriss's Avatar
Other Motorcycle: triumph daytona 955i
hi fred, i had same prob with kwak i owned and that was indeed the nuetral sensor, see you are also in uk, bet its raining as it has been here all day, good luck mate, kriss.forgot to say once i changed sensor problem solved.
kriss is offline   Reply With Quote
Old 10-15-2009, 12:41 PM   #4 (permalink)
DEcosse's Avatar
Definitely problem with the neutral switch - your work-around in the short term is to raise the side-stand first: that is the second interlock that applies when bike is not (or thinks it's not) in neutral.
Even when you fix the neutral switch, the bike will still 'die' if you click it in gear with the side-stand down. That is effectively what is happening now.
T'Rat.net BOTM November 2009
Old 10-15-2009, 03:05 PM   #5 (permalink)
freddie136's Avatar
electric fault
Hi, thanks every body for your helpful replies, i have changed the side stand switch, can you tel me where the neutral switch is located please and is it difficult to change, thanks once again, Fred
Old 10-15-2009, 03:18 PM   #6 (permalink)
DEcosse's Avatar
Shouldn't have needed the side stand switch Fred.
From described effect that one was working as it should.
You should find the neutral switch on the left side of the engine, down by gear shift pedal.
Item 24 - look for the harness wire attached to it
Fit new sealing washer (25) when you do.
Old 10-15-2009, 03:43 PM   #7 (permalink)
freddie136's Avatar
electric fault
Thank you for your help DEcosse, diagram much appreciated,will have a look in the morning as its night time over here just now,thanks again will let you know if i get it sorted or need more help,Fred.
Old 10-16-2009, 04:08 PM   #8 (permalink)
freddie136's Avatar
electric fault
Hi, again, fitted a new neutral switch today and bike fired up first time, so thanks to,[ sachem87184 ],[ kriss ], and [ DEcosse ] you were all right first time,thank you for your help much appreciated,cheers Fred
Old 10-16-2009, 06:25 PM   #9 (permalink)
DEcosse's Avatar
Good job Fred - glad it worked out!
help please electrical fault maxman915 Speed Triple Forum 6 03-25-2010 02:33 AM
Neutral Light Electrical Fault when riding in Wet Weather sloni Sprint Forum 2 05-17-2007 09:18 AM
Well I did it and it is your fault Scoobydo Speed Triple Forum 20 01-22-2007 11:34 AM
05/06 Fault ruscook Sprint Forum 72 12-07-2006 04:38 PM
electrical fault rg500-rider T3 Sport / Touring Forum 6 04-27-2006 04:17 PM
