digital gauges on 97-01 daytonas? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-14-2009, 08:00 PM   #1 (permalink)
Favourite Bike: 2001 Daytona 955i
can you fit a later model daytona's digital gauge onto the earlier model?
timwu is offline   Reply With Quote
Old 10-14-2009, 08:14 PM   #2 (permalink)
DEcosse's Avatar
It would be possible
The keys involve
1) splicing new connector to the OEM harness to mate with the digital cluster
(you can use a connector from a GSXR or similar headlight harness)
2) Installing a speed sender from 99-04 Sprint and wiring to the connector
3) custom circuit to drive the low fuel light (I have done this)
4) Validate/scale the temp signal as required.
And of course knowing how to do that!
Another alternative is to install a Sprint ST speedo in the tri-cluster and drive it with a Sprint Speed Sender. That will retain the OEM look but give you an electronic speedo.
http://www.triumphrat.net/speed-trip...ml#post1332132
T'Rat.net BOTM November 2009
Old 10-15-2009, 07:04 PM   #3 (permalink)
Favourite Bike: D955i 2001
L007's Avatar
Original instruments are sooo sexy, why change?
(I mean, is there any functional advantage on doing that?)
L007 is offline   Reply With Quote
Old 10-15-2009, 07:29 PM   #4 (permalink)
DEcosse's Avatar
I think the tri-cluster looks good too, L007 - electronic is an advantage though; functionally you can then add speed healer to get more realistic speed indication.
The latter option suggested above gives best of both worlds.
You could also easily replace the analog temp gauge with a digital one also!
Old 10-20-2009, 06:21 PM   #5 (permalink)
L007's Avatar
Well then, it would be nice to replace the speedo internals leaving the same graphics or either (donīt know how easy it would be) to recalibrate the original one. I heard that the error may be of 30 km/h, is that true?
Actually a GPS with a big digital speedometer would be even better. Perhaps a gear indicator would help too...
Digital Gauges on a Sprint Matix Sprint Forum 0 09-27-2009 04:11 PM
01/02 model Daytonas shiver Daytona Deliberations 6 09-14-2006 08:49 PM
91-93 daytonas andy_s Daytona Deliberations 0 08-17-2006 10:53 PM
Bucking Daytonas ??? soonerfan85 Maintenance & Workshop Talk 0 08-15-2006 01:43 PM
Any issues with '04 Daytonas'? AusSteve Daytona Deliberations 15 10-01-2005 07:42 PM
