Welcome to you both!
It's a good idea to put your year/model and location in your profiles - those will help as ready identifiers going forward, appearing in the left margin under your screen name.
Originally Posted by kriss
.... if you know which cylinder is not firing up on startup take plug out of that cylinder and if you have a syringe squirt small ammount of fuel into plug hole and reinstall plug if it then fires up you know its fuel....
Good suggestion when you have a common manifold from a single Throttle Body - however on the Triumph youhave individual TB's for each cylinder
So it's lot easier to just drizzle some - or spray - starter fluid straight into the TB's - you can test all three (independently) easily when it's running like this. Narrowing it down as Brad suggested is a good idea though
If not a plug or coil, then the injector is certainly a good candidate.
If you positively identify the issue as fuel, try a product called
Seafoam and see if that helps any.
Again drizzling it directly into the TB's is good for cleaning the combustion chamber, but won't do anything for the injectors, which will need to be through the gas.
Ultimately you can remove the injectors and have them professionally cleaned/flow tested. Much more cost effective than replacing!
A couple of good ones are
WitchHunter and
Injector-Rehab -
RC Engineering is also good but considerably more expensive
