BikeBandit
Old 06-12-2005   #1 (permalink)
I have a problem with the rear brake fading when hot from agressive riding on 04 d955. I an an old enduro rider & have the habit from dirt bikes of using rear brake to scruibb speed & control throtte during cornering & on the corner exit. My RC51 is not effected by this but the
Daytona rear brakes goes away in 30 minutes or so.
THe rotor is not out in the air being tucked in the wheel & may not be cooling correctly. ??? maybe better pads ??
Different brake fluid?? or just adjust riding style.
CL. :???:
Old 06-13-2005   #2 (permalink)
I didn't even know my Daytona had a rear brake, I kept pushing the pedal and nothing happened. No really, the rear brake is useless....John
RIDE IT LIKE YOU STOLE IT!!!!!!!
EUROTWINS is offline   Reply With Quote
Old 06-13-2005   #3 (permalink)
No rear brake is an understated !!!!! It has very poor feel & feedback. Goes from hardly working to locked up with no real feedback. I don't need much as I only really use it to smooth out power delivery & scrubb a little mid corner speed. This one goes to mush, pedal moves 2 inches after fluid boils, quite the reverse from the hard no feel. It's not a big deal but I'd like to fix it none the less.
CL
p.s love the bike other than that & the lean idle, will fix that with tuneboy.
Old 06-14-2005   #4 (permalink)
Never ridden one with Tuneboy,I went with PCIII and MHP high mount....John
Old 06-23-2008   #5 (permalink)
bikes have rear brakes? oh that's what that other useless foot control is for
apex eater is offline   Reply With Quote
Old 06-24-2008   #6 (permalink)
It's a heavy bike with a weak system. Call Brembo and throw 1K on a rear master cylinder. I suspect that if you found a bigger brake fluid reservior, you may be able to keep it cooler longer.
First, I would check make sure the caliper is working properly...pistons clean and returning evenly. Then I would put new pads is...worn out, thinner pads are going to transfer more heat to the fluid. Make sure the slide pin is clean and smooth and not binding on the pads.
Make sure the pedal, in its resting position is not dragging the brakes.
Make sure that your foot, in its resting position is also not dragging the brakes.
I have had no problems with my brakes. I do use the rear and it can be used effectively as you described. On the track, I rarely use the rear brake, but often do on the road.
02 Daytona 955i
Muzzy Exhaust
Racetech springs
Euroracing throttle
Tuneboy!
Pinballer is offline   Reply With Quote
Steel braided brake hose for rear brake midliferider Hinckley Classic Triples 4 05-20-2007 04:29 PM
Correct position for brake lever on rear conical brake johnquinnell Classic, Vintage & Veteran 11 03-09-2007 03:42 PM
Brake Fade 07 Model PoolyTriple Speed Triple Forum 10 03-07-2007 12:08 PM
Help - Front brake fade/lack of resisitance - not air?? NeilH The Rocket Science Forum 4 10-26-2005 05:48 AM
Daytona 900/1200 fr. brake fade Modifications & Workshop Talk 21 01-31-2004 04:37 PM
