Originally Posted by DEcosse
Is it only the speedometer part that doesn't work?
Yes
What did he use for speed sender?
It's still got the original mechanical sender on the wheel not connected to anything. So right now I don't have a speedo except for my GPS
HOWEVER - the Sprint 99-04 uses a 25mm electronic drive that is mechanically a perfect fit on the right side (Sprint & 97-01 wheels are interchanagable) and is also completely compatible electrically.
Great information! Do I need to source an ST wheel to make this work?
Incidentally with no speedo sender connected, there would be an MIL (Triumph speak for Check Engine Light : MIL = Malfunction Indicator Lamp) with a P1501 or P1502 Error code.
Would the codes show on the digital readout or do I need to get an OBDII reader to check them? I know the engine lamp is lit.
Regarding the low fuel - sorry if I confused - with the 02+ tank then there should indeed be no problem with the fuel sender - I meant if you intended to go back to 'older' style tank 'that' would be incompatible in that regard.
I'm working up a mount to use this thank. I've actually traced this tank back to the original owner and am waiting for any info he can give me on it. IE: what year it is.
The right side isn't bad.
The left side however is a rats nest. I'll be cleaning all that up correctly.
On a second look in the daylight it appears that the pipe is a slip on.
I also answered my own question on Body work. I found out the later lowers are not compatible with the 595T main fairing. I may be breaking out my fiberglass mat and resin to come up with some sort of workaround.
DEcosse, Thanks for all you help so far!
