Originally Posted by Prairie Rat
I am wondering if the fork tubes off a 1997 Daytona T595 will work on a 2001 Speed Trip. I dont believe there was any change was there?
They are the same.
Identical dimensionally and specifications/internals.
Axle/calioper mounts are also same.
Completely interchangable.
The top triple clamp is different between the two but the lower clamp/steering stem is same. But then you only asked about the tubes anyway!
