DEcosse - thanks for the thought ....the case cracked just inside of where the rear engine mount is located (inboard side of the mount, facing the 'center' of the cases. The crack runs from the base of the case, vertically, all the way up to the top of the case (I'd estimate about 6 inches +/-) and I'm not sure that a weld in this area won't cause more stress? I'm sure it's worth a try if you believe so but the question is whether it can even be welded at all since I think that the cases on this motor are sand-cast aluminum.
Does anybody know if you can weld cast-aluminum cases without causing 'other' issues? It's an easy job to drop the engine out but just don't want to be riding somewhere on a back road and have the engine case let go at the top of 3rd gear or something...
Equally as consterning is the prospect of having to swap my entire rotating assembly over into another set of cases....
As an aside, the 'original' (Daytona) engine that was in the bike has a weeping head gasket (#3 cylinder) but no apparent valve scoring or head warpage. Before I consider doing the head gasket, though, I'll have to unbutton the head and check the sleeves b/c when I took the airbox apart I found a LOT of sandy debris on the 'clean' side of the airbox stuck in filter oil...obviously from a poorly maintained foam filter and I'm not sure if any of that crap ever made it's way into the combustion chambers, although I'd have to expect so. This is a main reason I didn't rebuild the original engine to begin with.....I dunno.
Anybody know any private engine builders who could do a quality job of checking over my original engine for less than a full arm & a leg? North Brunswick, NJ area if you can recommend anyone. Thanks again, to all, in advance....
