Relays interchangable between years? - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 04-08-2009, 03:08 PM   #1 (permalink)
Favourite Bike: Daytona 955i 2005
I've had a few issues recently that would have been made easier to diagnose by having relays to swap in and out, so i was thinking about picking up a set second hand for that reason.
I have been offered a set off a 2003 955i and before buying then was just wondering if anyone knew whether they were interchangable?
Thanks,
Jamie.
dajamjar is offline   Reply With Quote
Old 04-09-2009, 02:38 PM   #2 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
Jamie, What year is your D955i? The relays are the same between 2002 and 2004 with the exception of the tip over relay (missing on the early production '02). I don't have the tail off the '04 to check, but some from the first gen D955 ('97-'01) may also be helpful.
HTH,
Brad
PS Look at bikebandit to compare part numbers.
Old 04-09-2009, 04:48 PM   #3 (permalink)
Sorry, thought i'd put that in the post. Its an '05, which isnt great news it seems
I'll hit bike bandit and see what it says, thanks.
Jamie.
Old 04-10-2009, 08:56 AM   #4 (permalink)
bradtx's Avatar
Jamie, I'm pretty sure the '05 and '06 are electricly the same as my '04, I just don't have either to double check with.
Brad
Old 04-14-2009, 06:05 AM   #5 (permalink)
Bike Bandit gives the same p/n across 2003 and 2005 so i went ahead and bought the relays, once they arrive i'll check again before fitting and post an update here.
Only potential issue is that, as i sometimes find, Bike Bandits part list doesnt fully match the schematic as there was a relay marked #15 in the schematic thats not in the list.
Like i say, i'll post once i've got them in hand.
Also due to take delivery if a Two Brothers high level Titanium exhaust today i got off a nice chap on eBay (i know, nice chap and eBay in a single sentence) so once thats on i'll post a week picture in the Show Us Your thread too.
Jamie.
Old 05-17-2009, 12:16 PM   #6 (permalink)
EDIT: DEcosse does a more accurate post below.
Old 05-17-2009, 01:51 PM   #7 (permalink)
DEcosse's Avatar
That's not correct.
Relay #3 is the headlight cut relay - that MUST be a 5-pin relay, same as you have installed in your '05
Headlights will not work at all with the 4 pin relay identified under your '03 listing.
I think what you're calling 5 is actually 7, the turn-signal relay and for those you purchased, the one that you have for #3 in the 03 line-up is really probably from position 6, the ignition relay, as it is the same as that type.
i.e. there are 6 relays total
4 x 4RA940010-71 for 1,2, 4 & 6 (Main Beam, Low Beam, Main Power, Ignition)
1 x 4R0003520-13 for 3 (Headlight Cut)
1 x 4DB003750-36 for 7 (Flasher)
Note that the numbering convention is a little odd:
they go 1-4 front to back along the right subframe rail, but then 5-7 from center to right (5 is not a relay, it's the fall detector switch)
T'Rat.net BOTM November 2009
Old 05-17-2009, 03:23 PM   #8 (permalink)
Hmm, i'll edit my post, sounds like the guy i bought these from has (by design or accident) done me out of one, ah well
Jamie.
Interchangable parts pickolas0990 Daytona Deliberations 1 10-26-2007 11:20 AM
interchangable wheels hkt100 Twins Technical Talk 11 01-30-2007 10:49 AM
are forks interchangable herald1200 Hinckley Classic Triples 1 11-28-2006 04:06 PM
interchangable parts? leroy_420b Daytona Deliberations 1 10-02-2006 10:20 PM
end cans interchangable Les Maintenance & Workshop Talk 2 06-08-2005 01:40 PM
