D12 Battery Problems - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports SportbikeTrackGear
Old 04-03-2009, 03:39 PM   #1 (permalink)
Favourite Bike: 2006 Daytona 955i
Hi there, I hope someone can help me. Ive got a 1993 D12, and am having some electrical problems. Ive had a new battery fitted after experiencing slugish starting, this hasnt improved the situation. The alternator is giving out over 14 volts, the battery shows 12.4 volts when its not under any load. On occasion the bike will not start at all, this can happen after a ride, or after being left all night. Its as if the battery is being discharged and is not holding any amps. Is the diode in the alternator supposed to prevent this? If so, can it be replaced as I dont want to replace the whole alternator when its not requirerd.
Is there any thing else that i should be checking?
Id appreciate any help with this problem as im at my wits end now.
Many thanks
John
spellbinder is offline   Reply With Quote
Old 04-03-2009, 07:51 PM   #2 (permalink)
Favourite Bike: 99 Daytona 1200
Other Motorcycle: 07 Scrambler/ Velorex
Extra Motorcycle: 99 Daytona 1200
I would be inclined to check all connections in the starter circuit, sounds more like the juice just isn't getting through.
cbwright is offline   Reply With Quote
Old 04-04-2009, 02:13 PM   #3 (permalink)
Thanks for the reply, ive checked all the connections, and they are all OK. It seems to me like the battery is being drained and doesnt have enough amps to turn the bike over, even though its still giving out 12.4 Volts.
Old 04-05-2009, 10:41 AM   #4 (permalink)
Favourite Bike: 02 D955i
drakewn's Avatar
Is anything getting hot while you're trying to start it? I'm not sure if you have a regulator/rectifier/ground block, etc. What happens if you try to boost it with another vehicle? Does it start normally sometimes? I think the starter itself could be an issue.
That's all I can think of for now. The sun is coming up and it's time for me to go to bed.
drakewn is offline   Reply With Quote
Old 04-11-2009, 10:33 AM   #5 (permalink)
Favourite Bike: 1993 D1200
Other Motorcycle: K100 forthcoming project
Extra Motorcycle: R75/6 ongoing project
battery problems
One thing I can think of:
Do you have an immobiliser of any sort? I had one, and had assurances that the load was nowhere near enough to drain battery. So put up with rubbish starting, if at all, whilst trying to find another fault.
Then got rid of immobiliser - perfect starting every time now.
Cheers
Rich
richh is offline   Reply With Quote
odd battery problems with my Tbird salamander Hinckley Classic Triples 13 03-27-2008 08:15 AM
Battery Problems Newby Daytona Deliberations 11 08-30-2007 12:49 AM
Battery Problems - HELP! wongl10 Twins Technical Talk 8 08-20-2007 04:18 PM
Battery problems zippythehog Maintenance & Workshop Talk 4 09-14-2006 02:43 PM
Battery? Earth problems? Fozzy Hinckley Classic Triples 4 04-04-2006 05:14 PM
