Bob, Turn the key on, go to the clock and press reset and hold. The temp readout and the speedo will cycle through four different possible combinations (MPH, KPH, C and F). When the desired combo appears, release the button. To set the clock press select and reset at the same time 'till the hour flashs.
Brad
