Sidestand bracket seepage again 02 Daytona - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleMotorcycle.com Classifieds!Ontario Tourism
Old 03-26-2009, 10:52 PM   #1 (permalink)
Other Motorcycle: CB360 Racer
After sealing up the sidestand bolts last year due to an oil leak, it started leaking again. I hate leaks near tires!
I first used teflon tape but that did not last. I then used black permatex and it was great for a few thousand miles. I noticed a few more drops on the floor after recent rides so I removed the entire sidestand assembly (not just one bolt at a time like before), and discovered that the sidestand switch plate that is sandwiched between the ss bracket and motor was soaked in oil. The bolt hole surfaces on the motor have a rough finish and Triumph put no sealer between them.
This time I put a nice bead of red RTV on all the mating surfaces and all is well and should stay that way forever.
I would check yours...
02 Daytona 955i with Muzzy Exhaust, Racetech springs,
Euroracing throttle, Double Bubble
18/44 gearing
Tuneboy!
Pinballer is offline   Reply With Quote
Old 03-26-2009, 10:59 PM   #2 (permalink)
Favourite Bike: 02 D955i
drakewn's Avatar
Thanks, I'm going to do that when this f'n snow melts.
drakewn is offline   Reply With Quote
Old 03-28-2009, 12:18 PM   #3 (permalink)
DEcosse's Avatar
Originally Posted by Pinballer View Post
...The bolt hole surfaces on the motor have a rough finish and Triumph put no sealer between them. ...
Well, they put no sealer in there, because there should be no reason to - that should not require a sealed joint and its only because of the crappy cases that it is occurring to begin with.
So the RTV is a band-aid (a good one!) literally! to prevent the oil making it out to the outside world.
But we shouldn't be slamming them for not sealing this joint, the slam should be on oil getting out those holes to begin with!
It's unbelieveable this should even be a problem!
We know that it does happen - but it's quite ridiculous.
In my case, mine leaks through one of the sprocket cover holes. Took me forever to find it!
T'Rat.net BOTM November 2009
Sidestand bracket on Sprint Sports shemp T3 Sport / Touring Forum 2 04-17-2008 08:29 AM
Trophy Sidestand Bracket dcl5ah Trophy 1 03-12-2008 12:13 AM
T312 Daytona sidestand (Help!) docradio Daytona Deliberations 2 11-06-2007 03:54 PM
sidestand & bracket replacement on a Trident djw T3 Sport / Touring Forum 1 06-19-2007 10:53 PM
94 Daytona bent side stand bracket Pipes Daytona Deliberations 2 04-15-2004 08:20 AM
