cheap+wrong oil = slippy clutch t-595 , 955i - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!Ontario TourismHonda Powersports
Old 03-23-2009, 05:04 PM   #1 (permalink)
k
so i used mobil 1 and i believe it was the wrong stuff ( maybe an additive) . so now when i wind it up in 4th gear ( and 5th and 6th) it slipps then grabs.
the bike has 13 k on it , i never wheelied it too much ( 15 - 3 gear , from first)( type wheelie) , really not too bad
the bike spends a very good portion of its life @ 140 mph.
the question :
being that i allready know im going to have to replace my clutch --- should i go and dump a can of "prolong" or some other " slik" ( in more than one way ) type of oil in the bike? , drive it around and then replace the clutch?
next question:
are there clutches that can operate in " a funny oil enviroment"?
like aftermarket clutches ( names or brands please)
do i have to buy a complete gasket kit to get a clutch cover gasket?
is replacing the clutch as straight foward as i might think it is ( pop cover (with the greatest of care as not to damage the gasket ) , remove top of basket , replace discs with new discs ( and springs ) , stick it together ( minding excact tourqe specs for every bolt touched )? - or more diabolical ( like the bolts have to be tourqed on the second full moon)
thanx any input or thoughts would be great
raggedraider is offline   Reply With Quote
Old 03-24-2009, 06:29 AM   #2 (permalink)
Favourite Bike: 2007 SprintST1050
NEV1050's Avatar
Other Motorcycle: 2003 Daytona 955i
Extra Motorcycle: 2003 Suzuki GSXR1000,
When you say you used Mobil 1 was it car oil as this has friction modifiers in it to reduce wear(so they tell us ). Mobil1 4T is a Motorcycle specific oil which will not have a bad reaction to your cluch. If it wasn't slipping before the oil change, dump the oil and get new oil that is designed for 4 stroke bikes with wet cluch and it should be all good again.13,000ks should be nothing for a cluch and should be o.k for ages.
Cheers, Nev
NEV1050 is offline   Reply With Quote
Old 03-24-2009, 06:49 AM   #3 (permalink)
im gonna guess it had some additive
but
do you think th additive might "wear out or off the clutch discs"?
its worth a shot - i dont want to crack this thing open if i dont have to
if ihave to replace the clutches im very tempted to hit it with prolong like stuff
thanx
Old 03-24-2009, 09:31 AM   #4 (permalink)
NEV1050's Avatar
The additves in the oil are the cause of the slipping. Cars don't run wet cluches so they want everything to be as slippery as possible to avoid engine wear.
I have friends who have not replaced a cluch for 60,000 ks and are still going strong.
Change your oil to BIKE specific oil and forget the prolong or other crap. You do not need anything else apart from good engine oil ,otherwise all manufacturers would use the additives.
You will NEVER find a manufacturer who recomends anything other than oil in their engines. You are just throwing your money away for no gain.
In your Triumph Owners Manual it says NOT to use anything else apart from OIL.
Drop the mobil1 and replace with good Bike oil and you will fix your problems without having to change your cluch. Don't use car oil in your bike.
Old 03-24-2009, 10:42 AM   #5 (permalink)
Favourite Bike: 1999 Daytona 1200SE
JohnD's Avatar
Other Motorcycle: '08 Kawasaki Concours 14
Extra Motorcycle: a.k.a. GTR 1400
NEV1050 has it right, but I will just add a little reinforcement.
The Triumph recco is to use fully synthetic Mobil 1 Racing 4T 15W/50. Depending on weather where you live, you can use 10W/40 too. A similar high quality brand is OK to use, but must always be a MOTORCYCLE oil.
Do not forget to change the oil filter at the same time or you will be leaving some of your cheap oil in the engine.
JohnD is offline   Reply With Quote
Old 03-24-2009, 07:02 PM   #6 (permalink)
coool
Old 03-25-2009, 06:52 AM   #7 (permalink)
NEV1050's Avatar
Thanks for the backup JohnD.
Let us know when you change the oil and give us the results
Where do you live to be able to ride at 140mph all the time?
Here in the Northern Territory we had an open speed limit untill 12 months ago.
Now the Guvmint has allowed us to travel at 130kms/hr on the open highway. How terribly good of them,Not.
Old 03-25-2009, 02:43 PM   #8 (permalink)
new jersey usa
i pulled a slightly less than 25 min ride from barnegat nj to matawan nj
on the parkway exits 67 to 120
id hate to encourage it
i also did a ride to morristown on 287 (from x 120 pky) in like 22 min
again not recomended --(and questionably ethical)
i do video some of it (sooner or later it will hit youtube)
the bike had held a peak speed on a gps of 169 mph , for 4 min -all stock with the exception of 2 teeth taller in the rear sproket
again at those speeds its "VAPORIZED" not "KILLED"
im on stock tyres.
im doing the oil this weekend we will see.....
Old 03-25-2009, 03:08 PM   #9 (permalink)
Favourite Bike: '05 T100
Hi,
I just wrote this into another thread but it bears repeating:
Use oil with the "JASO MA" certification. It is true you can find other oils that do not have the friction modifiers and which do not have this certification. It is true that they will work fine. I am not arguing that point at all. But you can definitely eliminate a guessing game if you use oil with the JASO MA certification. I would not think you should have to do anything else. This will probably "fix" your clutch. I know I'm Bonnie owner writing in a Dayton thread but this oil is definitely the stuff for wet clutches on motorcycles. JASO MA means it IS a motorcycle oil.
Good luck
Geimer is offline   Reply With Quote
Old 03-25-2009, 04:01 PM   #10 (permalink)
is awsome info
even though im gonna dump what ever the dealer says into the bike
( untill i get this clutch thing worked out )
but after that , likely something else.
i was under the impression that if i used "additive oil " it would be absorbed into the plates and not likely "cooked"out
it would be nice to not have to buy a clutch , and a gasket kit ( for one gasket )
thanx
Slippy brake pedal.. Bigngreen Tiger Mods & Bolt-Ons (archive) 11 04-30-2009 01:10 AM
cheap clutch bolts upgrade look Twins Technical Talk 0 08-10-2008 03:07 PM
Long shot, anyone got a cheap/scored liner and piston from a 955i? MJJ_ZX6RR Daytona Deliberations 0 07-31-2008 10:26 AM
2004 Daytona 955i, CHEAP! $6000 Smartdrug Daytona Deliberations 4 06-15-2007 12:24 PM
slippy seat oldgimmer Tiger Mods & Bolt-Ons (archive) 8 02-03-2007 01:43 PM
