Help! 1999 Daytona Electrical Issues! - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Motorcycle.comMotorcycle.com Classifieds!SportbikeTrackGear
Old 03-19-2009, 10:46 PM   #1 (permalink)
Hears the deal..when i turn the ignigtion switch on my 1999 Daytona It will not start no power to starter the front or rear lights dont come on and the temp gauge goes all the way up up stays there after i switch ignigtion off. No luck jumping:it from car. no luck push starting it neither.
Any help would be greatly appreciated!!!!
Robcampbelljr is offline   Reply With Quote
Old 03-20-2009, 01:46 AM   #2 (permalink)
Favourite Bike: '03 Daytona 955i
HiDesert's Avatar
How's the battery? Checked the fuzes/relays? Is this the first time you've tried to start it in weeks/months?
I won't stop riding because you tell me about someone who died in an accident, just as I won't stop eating because someone died of e.coli.
HiDesert's ride photos
HiDesert is offline   Reply With Quote
Old 03-20-2009, 09:21 AM   #3 (permalink)
Favourite Bike: '04 D955i
bradtx's Avatar
Other Motorcycle: '98 T595
For starters, if you have a voltmeter, check that the battery hasn't changed polarity (can happen when a battery goes dead).
Brad
Old 03-20-2009, 08:48 PM   #4 (permalink)
I went out bought a new battery charged it and changed all fuses no results any suggestions about what relays i should test?? Could ignition switch be problem?
Old 03-21-2009, 09:55 PM   #5 (permalink)
Favourite Bike: '06 Daytona 955i
PaulR's Avatar
Other Motorcycle: '97 BMW R1100RS
Extra Motorcycle: '98 Yamaha R1
Need more information - how long is it since the bike last ran? Were there any electrical problems before? Have you checked the fuses? Have you established that there's a good earth from the battery to the engine/frame?
It could possibly be a short or break in the wiring from the ignition switch, where it flexes as the steering is turned. Wiring is prone to fracturing there.
PaulR is offline   Reply With Quote
Old 03-21-2009, 10:37 PM   #6 (permalink)
I had a similar problem turn out to be a relay
hintonrsvr is offline   Reply With Quote
Old 04-08-2009, 10:48 AM   #7 (permalink)
Almost there!
It was relay but now my brake light wont come on but brake light does work when i hit brake lever?????jeez
Old 04-08-2009, 09:18 PM   #8 (permalink)
VMax's Avatar
Thumbs up
I had problems with the wiring running to the rear brake lever. It was rubbing against the frame and shorting out. The wire routing on the Daytona is pretty ****house. Re-route and then insulat it. Should be no further problems.
VMax
VMax is offline   Reply With Quote
1999 1200 starting issues Mike The Bike Trophy 10 04-01-2009 07:43 PM
Another thread on electrical issues Noober Triumph SuperSports 3 12-20-2008 05:23 PM
Electrical issues BlackThrux Club Cafe' 3 01-14-2008 12:58 PM
Electrical Issues? Wilson Triumph SuperSports 2 06-10-2006 07:45 PM
1999 Sprint ST Electrical Gremlins Belway Maintenance & Workshop Talk 3 06-04-2006 05:42 AM
