leaking gas
I just bought a 01 daytona 955i. the tank is leaking around the seal for the fuel pump. Put new seal in and is still leaking. called a dealer they sais it could be a bolt hole as the leak is on the top. anyone know anything about a leak like this. seams like to much pressure in the tank, forcing gas out of the seal. dealer said requires 50 psi in tank. please help.
