Hello all,
newbie goof alert here. a little back ground on my mods. A few months ago I replaced the rear tail light with an LED version and also replaced the rear turn signals with retro non Led lights as well. I remember when I was installing I kept blowing fuses left and right I figured I was fat fingering the connections. Long story short the bulb for the parking light went out and I didn't care to replace it as I never use that. everything worked perfect after the install.
Bike turn signals were running perfect for months until I decided to paint the front light can which I did, upon reinstall I figured I would add a new bulb(194 type) in the headlight. once I put everything back together I was checking the light and all the lights work except the 4 Turn signals, I checked the fuses and they all seem ok. it seems to be connected to me adding the parking bulb or at least that's what I think. other than that what could I be messing up here??
Any help would be greatly appreciated.
Regards
Regards
