Will a 2009 solo seat fit a 2010 ??? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 11-24-2012, 07:50 AM   #1 (permalink)
Main Motorcycle: 2010 Triumph Speedmaster
PRM068's Avatar
Can anyone please advise.....I have an opportunity to buy a 2009 America solo seat for my 2010 Speedmaster. The part number appears to be 2305680, but I've done searches for Triumph Parts Numbers and am still none the wiser.
Will it fit, or are the 2010 models somehow different ? Also looking at pillion seat from a 2009.
Thanks,
Peter
PRM068 is offline   Reply With Quote
Old 11-24-2012, 08:17 AM   #2 (permalink)
Main Motorcycle: Triumph America
Thanks,
Peter
Yes ,remove the quick release catch and underneath the catch is a cage nut you can bolt the seat to
huggy39 is online now   Reply With Quote
Old 11-24-2012, 10:27 AM   #3 (permalink)
Main Motorcycle: 2012 speedmaster
vince64's Avatar
Other Motorcycle: xj900s diversion
Hi, I have just fitted a maverick solo seat to my 2012 speedmaster.
its staight forward to fit even tho triumph say you cant fit a solo seat to later models
first undo the allen head bolt at the rear of seat , pull the quick release ring under the left hand side of seat and remove seat.
undo the 2 allen head bolts that are holding the release spike on {you will have to hold the nuts under the mudguard still } and remove the spike unit .
this will expose a threaded nut welded under the mudguard for you to fix your solo seat to .
so yes you can fit a solo seat to any model speedmaster .
vince64 is online now   Reply With Quote
Old 11-24-2012, 12:19 PM   #4 (permalink)
Main Motorcycle: Speedmaster 2012
Other Motorcycle: Transalp XL700 VA
As described above, you can fit an older model solo seat to your speedmaster. I just got my new 2012 matte black Speedie and fitted an older OEM solo seat. Fits perfectly and looks great.
CrazyTrain is online now   Reply With Quote
Old 11-25-2012, 01:43 AM   #5 (permalink)
PRM068's Avatar
G'day guys,
thanks very much.
My original post was done in haste, because i simply needed to know fast, and I really appreciate you getting back to me.
I'll let you know how I go.
Peter
Old 11-25-2012, 06:20 AM   #6 (permalink)
Main Motorcycle: 2012 Speedmaster
I did find the part number on 2WheelPros.com:
http://www.2wheelpros.com/oem-parts/...5680-part.html
Interestingly enough, the site shows the seat will fit all model years EXCEPT 2009 and 2010. I did a similar search on BikeBandit.com, and got the same result. Now, if you are certain the seat came from a 2009, then it probably is a safe bet it will fit on the 2010, but I'd only buy if it there is a return policy no questions asked.
cjpeltz is online now   Reply With Quote
Old 11-26-2012, 04:02 PM   #7 (permalink)
PRM068's Avatar
hey guys,
well, picked up my solo and pillion seats yesterday - look good.
Now the fun begins. i have to get the right bolt to fit on to my Speedy - one that not only secures the solo seat, but then allows the pillion seat to be slipped on.
The solo seat actually looks to be stamped as an "01" seat - please tell me there won't be any problems fitting it ? i had a play last night (without the attaching bolt) and it seems to fit. Trouble is I can see that the pillion seat will need the right bolt to be secured properly.
I don't suppose anyone has a picture of there's.?
Mine is a 2010.
Peter
Old 11-26-2012, 04:23 PM   #8 (permalink)
hey guys,
Mine is a 2010.
Peter
If you are fitting a pillion seat as well, you require the special bolt with a groove in,(from triumph) to allow the pillion seat to slide into, and is locked in place with the rear bolt
Old 11-27-2012, 05:16 PM   #9 (permalink)
hey guys,
Mine is a 2010.
Peter
Hi Peter
Here is the picture of the bolt you need. This came with my solo seat
fitting a 2004 solo seat to a 2010 speedmaster shannonlec Cruisers - America, Speedmaster 4 01-19-2011 07:18 AM
My solo road trip, IL/MO/AR/etc, 2009 MattMatt Ride / Trip Reports 1 08-14-2010 08:47 PM
Speedmaster solo seat vs. Corbin solo seat Trump Twins Talk 0 04-26-2006 05:20 PM
