Heated Grips - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 11-17-2012, 04:41 PM   #1 (permalink)
Main Motorcycle: Triumph speedmaster
Jonnybravo's Avatar
Heated Grips
Is there a plug under the tank on speedmaster to plug heated grips into?
If so what make grips?
Jonnybravo is online now   Reply With Quote
Old 11-17-2012, 06:13 PM   #2 (permalink)
Main Motorcycle: 1971 TR6R Triumph Tiger
johnquinnell's Avatar
Other Motorcycle: 2006 Triumph America 790
I've run Oxford heated cruiser grips for the last 2 years without a single problem. All the necessary wiring reqd is supplied in their kit.
johnquinnell is offline   Reply With Quote
Old 11-26-2012, 02:17 PM   #3 (permalink)
Jonnybravo's Avatar
Do they just plug straight in then?
Or is there wiring to do?
Old 11-26-2012, 03:29 PM   #4 (permalink)
Main Motorcycle: 2012 speedmaster
vince64's Avatar
Other Motorcycle: xj900s diversion
Oxford heated grips come complete with there own wiring loom , all you need to do is connect everything up then connect the live to a good live or direct to the battery and the neg to a good earth or again direct to the battery . I have used oxford grips on 2 bikes for many years wired direct to the battery with no problems ..
vince64 is offline   Reply With Quote
Old 11-27-2012, 11:46 AM   #5 (permalink)
Main Motorcycle: Thunderbird SE
Tipsi's Avatar
There is no plug and play grips i'm afraid, it's a wiring job, embrace the challenge I use heat demons, very tidy install & no big control box...
Tipsi is offline   Reply With Quote
Old 11-27-2012, 02:49 PM   #6 (permalink)
Main Motorcycle: 2012 Speedmaster
I stumbled across the Oxford Hot Hands - http://www.webbikeworld.com/r3/heated-motorcycle-grips/ - which fit over the existing grips and can plug directly into the SAE socket near the battery. Seems these would be plug and play, but I don't have any experience with them.
cjpeltz is online now   Reply With Quote
Old 11-29-2012, 08:13 AM   #7 (permalink)
Jonnybravo's Avatar
Im at the NEC Bikeshow,just been on the triumph stand and the guy told me that heated grips wont work on my Speedmaster? He said i advise you not to fit them,they will flaten the battery?
Old 11-29-2012, 08:41 AM   #8 (permalink)
Tipsi's Avatar
Jonny, been running my heat demons all last winter and with our weather most of the year with no problems, they do only draw about 3 amps. I can't speak for Oxford products as I've never owned then but a believe there can be an issue with the controller
Old 11-29-2012, 08:45 AM   #9 (permalink)
Tipsi's Avatar
Cjp, I'd worry about wrapping something around the grips, would they slip etc, wiring things directly to the battery would would but forget to switch them off and you've got a flat battery in minutes use a relay and find a switched live.
Old 11-29-2012, 12:09 PM   #10 (permalink)
Jonnybravo's Avatar
I bought Oxford Cruiser heated grips.
Just got to fit them nw and to my dads America.
Heated Gloves or Heated Grips? sid001 Tiger Chat 20 10-28-2010 03:50 PM
heated grips vs heated gloves Razzoo Sprint Forum 22 01-08-2010 11:48 AM
heated grips vs. heated gloves ??? bikebudha1 Thunderbird Cruiser Chat 4 10-12-2009 03:10 PM
Wanna trade grips? OEM Heated for your OEM non heated? Tattoed Red Head Sprint Forum 29 02-14-2009 05:31 PM
NEED HELP WITH HEATED GRIPS thinkjerm Sprint Forum 4 06-17-2007 10:20 AM
