Swing arm length - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.com
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 11-17-2012, 11:52 AM   #1 (permalink)
Main Motorcycle: '52 Vincent B/L
Flaco's Avatar
Other Motorcycle: '05 Bonneville
Extra Motorcycle: Past / '65 TR5
Swing arm length
What is the length of a S/A swing arm. (C/L of swing arm pivot to axle C/L) ?
I'm building a "soft tail" Bonneville bobber and may utilize a S/A swing arm.
Bonneville's are 19", 482 mm...
Thanks...
Allin
'05 Bonnie, 73 RWHP "Goodwood Green Chili Dancing Machine."
Flaco is offline   Reply With Quote
Old 11-19-2012, 01:20 PM   #2 (permalink)
Slinky's Avatar
I make mine 22", although the axle position is a variable. The width may be an issue.
Old 11-23-2012, 06:44 AM   #3 (permalink)
spunebil's Avatar
Where are you putting rear shock in your design ?
spunebil is offline   Reply With Quote
Old 11-25-2012, 02:35 PM   #4 (permalink)
Main Motorcycle: '03 America
Other Motorcycle: GS750 rat
Extra Motorcycle: GS750 chop
I see it as:
~21.5" C/L of the pivot to C/L of axle slid all the way forward.
~11.25" wide ID between the frame at the pivot point, with some room to play with spacers on the left (this is my least confident measurement as I'm not willing to pop the chain guard off unless requested ...maybe +/- .25").
~10.375" ID between the axle plates.
Verde is offline   Reply With Quote
swing arm daveyl Daytona Deliberations 15 07-23-2012 06:36 PM
Pads to length center-stand feet longer? (for using thruxton-length shocks) STW Twins Talk 5 06-22-2012 09:07 PM
Swing arm Length? The Twig Sprint Forum 10 02-17-2012 03:45 AM
'71 swing arm length... mill3rk Classic, Vintage & Veteran 9 09-09-2011 04:33 PM
Swing Arm .... NewMetal Twins Technical Talk 4 05-09-2007 04:24 AM
