Cush drive replacement - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGear
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 11-13-2012, 01:14 PM   #11 (permalink)
Slinky's Avatar
I'm not sure, maybe it is better material. My Thunderbird has 43k on it and no slop in the cush drive, so it seems to last better.
Originally Posted by skromfols View Post
Slinkey, what makes the cush drive from the Thunderbird triple better? I already have a replacement on order, but if this one only lasts 20,000 miles I may need to get one of the Thunderbird cush drives.
Old 11-14-2012, 10:10 PM   #12 (permalink)
Main Motorcycle: 05 Black Speedmaster
So, is the thunderbird cush rubber identical to the speedmaster / america back wheel, a direct replacement?
Old 11-15-2012, 03:18 PM   #13 (permalink)
Slinky's Avatar
I have read that it is a perfect fit but I have not tried yet, I'm waiting till next time the wheel comes off. It's not entirely identical- my Tbird rubber is one peice and I seem to recall the one in my Speedie is multiple pieces.
Old 11-15-2012, 04:31 PM   #14 (permalink)
Main Motorcycle: 98 Valkyrie
Other Motorcycle: 08 Triumph America
The cush drive on my America is one piece. hahaha, well it used to be.
Stan
08 America, Bub slip ons, A/I removed, emissions "stuff" & air box removed, billet intakes, UNI Pods, rejetted, carbs balanced, intminators, Progressive 412's, 1" risers, seat modified by Spencer, TP USA Option 2 Igniter, 813 cams
skromfols is offline   Reply With Quote
Old 11-16-2012, 09:53 AM   #15 (permalink)
Main Motorcycle: 07 speedmaster
wildchild's Avatar
Other Motorcycle: 07 675 Daytona
I used a cush drive from a tbird sport no play yet got over 20000 miles on it. The first time replaced it with a speedmaster cush drive 1000 miles it had play in it the tbird cush drive fits real snug in the hub where the other one just drops in think it has play in it right from the go
Jerry
toys for big boys
wildchild is offline   Reply With Quote
Old 11-25-2012, 08:58 PM   #16 (permalink)
Main Motorcycle: 03 Bonneville America
Gregger's Avatar
Other Motorcycle: 69 BSA 650
I have 48,000 kilometers on my 2003 America and have never changed the cush drive. When the play showed up early on, I cut an old leather belt up placing equal length pieces of the belt on the backside of the rubber modules of the cush drive taking up any play. Did this 20,000 kms ago. Still no play.
Can't wipe this smile off my face!!!!
Gregger is offline   Reply With Quote
Old 11-27-2012, 02:30 PM   #17 (permalink)
Main Motorcycle: Bonneville America
grzegorz's Avatar
Thunderbird triple cush drive is tight fit ..weel has no play ,is direct replacement (as is thunderbird rear wheel) is in one piece as it should be....first time fitting is a bit of pain...is really tight
pictures
grzegorz is offline   Reply With Quote
Old 11-27-2012, 06:13 PM   #18 (permalink)
Maverick72's Avatar
The original Speedy and America Cush drives are pretty soft for a Cush drive..
My speedy's got 20k miles on it. The Cush drive was shot at 11k.
Replaced it with a thunderbird sport Cush, (easy job to change), and had no problems since..
Veho Libertas
Maverick72 is offline   Reply With Quote
Old 01-04-2013, 10:11 AM   #19 (permalink)
Well, I finally have the time to replace my cush drive. I haven't had to remove my rear wheel for any reason yet, so I have no idea how difficult this job is going to be. I have the Haynes manual and hopefully that will at least cover the removel and replacement of the rear wheel.
Stan
Old 01-06-2013, 11:24 AM   #20 (permalink)
GJT
Main Motorcycle: Speedmaster
Hey Stan, a fairly straight forward job, an extra pair of hands and removing the shocks
come in handy during re-assembly especially on the brake side. Although it can be a one man job if you know all the choice words !
GJT is offline   Reply With Quote
About to tackle cush drive replacement. tubbyhubby Sprint Forum 4 10-10-2012 05:05 PM
What to use to lube the cush drive? Bhodi513 Twins Technical Talk 25 01-25-2011 10:12 PM
Cush drive bad? trashman Twins Technical Talk 10 08-05-2010 07:41 AM
Replacement Cush Drive??? crowtherstephen Tiger Workshop (archive) 8 07-14-2009 08:06 AM
