Switching handlebars - Triumph Forum: Triumph Rat Motorcycle Forums
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 10-27-2012, 07:34 PM   #1 (permalink)
Main Motorcycle: 98 Valkyrie
Other Motorcycle: 08 Triumph America
Is anyone who has changed the handlebars on their America or Speedy willing to explain how to get the hand grips off. I bought a new set of handlebars but have no idea how to get the grips off. They don't seem to be glued on, but they don't want to come off.
Stan
08 America, Bub slip ons, A/I removed, emissions "stuff" & air box removed, billet intakes, UNI Pods, rejetted, carbs balanced, intminators, Progressive 412's, 1" risers, seat modified by Spencer, TP USA Option 2 Igniter, 813 cams
skromfols is offline   Reply With Quote
Old 10-27-2012, 07:39 PM   #2 (permalink)
Main Motorcycle: 07 Tiger 1050
duncan67's Avatar
Other Motorcycle: 07 Tiger 1050
Extra Motorcycle: Bonneville America
Dont they simply come off as a unit ? I could have sworn thats how it was when I did mine a while back.
I admire harly riders greatly.How brave they must be to take to the hiways and byways on a motorcycle so bereft of handling and horsepower!
duncan67 is offline   Reply With Quote
Old 10-28-2012, 04:54 AM   #3 (permalink)
Main Motorcycle: America and Speedmaster
JKDude's Avatar
I used a screwdriver to break the seal. No damage done.
Sent from my Nexus 7 using Motorcycle.com Free App
JKDude is online now   Reply With Quote
Old 10-28-2012, 05:53 AM   #4 (permalink)
Main Motorcycle: My T100
jd_t100's Avatar
Get some hand sanitiser from the supermarket. The one to wash your hands without water. It evaporates really quickly. Then get a flat head screwdriver and lubricate it with the sanitiser. Use the screwdriver to force in under the grip along the handlebar which will also leave some sanitiser in there. From there you will find the grip becomes loose and will slide off.
Its also good to lubricate the grip on the inside before you want to put it back on and it will slide on no problem. Once it dries, it stays on firm.
2007 Bonneville T100. Chrome cam covers/chain guard/headlight bracket/brake fluid cap/front mud guard. Madaz pipes. AI removed. BC ARK. Centre stand. Thruxton gel seat. British Customs clubman bars. Napoleon bar end mirrors. Dart screen.
jd_t100 is offline   Reply With Quote
Old 10-28-2012, 08:32 AM   #5 (permalink)
Ru55boy's Avatar
I've always used windex, or any spray on glass cleaner.
Gently push the end of a flat head screwdriver under the rubber and squirt in the glass cleaner, try twisting the grip, skirt a bit more, push the screwdriver in a bit further and eventually it will all go loose and slip off.
Then give the bars a wipe.
To fit grips I use hairspray on the bars, the grips slip on nicely and the hairspray drys sticky after 5 or 10 mins.
Sent from my Motorcycle iPhone app
Ru55boy is offline   Reply With Quote
Old 10-28-2012, 08:59 AM   #6 (permalink)
Main Motorcycle: The one I am riding
Other Motorcycle: Ducati ST4s
Extra Motorcycle: Triumph ST1050 - any day
Get a hair dryer on it for 5 mins - much, much easier
johnnyst is offline   Reply With Quote
Old 10-28-2012, 10:01 AM   #7 (permalink)
Thanks guys, you've given me some good information. I'll give it a try a little later today.
Stan
Old 10-28-2012, 12:01 PM   #8 (permalink)
Main Motorcycle: '12 Street Triple
I used WD-40 on my America grips, but as mentioned above it does not evaporate, though i never had any problems. More recently on my street triple i used a can of compressed air, sticking the straw into the grip pulling and twisting at the same time the air shoots in. Worked terrifically and no residue of any kind to deal with, just have someone hold your bike when you do it.
jbamerica is offline   Reply With Quote
Old 10-28-2012, 08:26 PM   #9 (permalink)
Thanks to all of the suggestions I was able to get the grips off with no problem. I had a long, stiff wire and I slipped it between the bars and the grips, then used WD-40 that had an injection tube. They slipped off with no problem.
Now I'll have to read up on how to take the clutch and throttle assemblies off without doing anything stupid. I have the Triumph repair manual and glanced at it quickly before I called it quits today and they seem to address what needs to be done. But if there are any suggestions I'm always ready to consider what's worked for someone else.
Stan
Old 11-08-2012, 06:56 AM   #10 (permalink)
Main Motorcycle: 2002 Bonneville America
+1 on the WD40. I have alwys used that. As stated above, make sure you clean the bars and grips good before replacing them. I have reinstalled using hair spray and it's worked well for me.
freddyknuckles is offline   Reply With Quote
Switching from and ST to GT steveno Sprint Forum 21 10-19-2010 10:30 AM
Switching Bonnie handlebars to 1" clip-ons - BonnieBlack07 Twins Technical Talk 14 01-22-2010 08:57 AM
Thruxtons switching to handlebars? MotoBuddha Twins Talk 5 02-17-2008 02:25 PM
thinking of switching from the r3 to s3 Briank Speed Triple Forum 9 10-02-2006 11:37 PM
Switching to Unleaded Classic, Vintage & Veteran 16 01-02-2005 09:13 PM
