Norman Hyde bell mouth install possible dilemma - Triumph Forum: Triumph Rat Motorcycle Forums
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
post #1 of 11 (permalink) Old 10-24-2012, 08:49 PM Thread Starter
Main Motorcycle: 2009 Speedmaster
SpeedBirdTT's Avatar
Other Motorcycle: 2000 Legend TT
Extra Motorcycle: 2010 Thunderbird
I have a 2009 Speed master thinking of installing Norman Hyde bell mouth except I noticed after snorkel removal the cap has a plug going onto it that is not on the Norman Hyde Bell mouth I do not know what this plug is for it plugs into the slat below my thumb in pic.
SpeedBirdTT is offline
post #2 of 11 (permalink) Old 10-25-2012, 01:25 AM
Main Motorcycle: 2009 Blue & White America
MattyMo's Avatar
That is your OBD II port, to connect to your motorcycles ECU. Stored on the perch molded into the air inlet. If you loose the perch you can loosely strap the cable/connector down to the frame for storage.
edit: I just removed the snorkel and enlarged the inlet to the ID of the filter. Done with some other work and dyno-tuned with added air flow. Sure, it's a bit crude compared to a bell mouth or a the new "breathe" inlet (looks really interesting).
2009 America with some mods, a lot of fun that I can ride all day. (sold and miss my 2008 Bonneville, a great daily driver)
this message was created using recycled electrons
MattyMo is offline
post #3 of 11 (permalink) Old 10-25-2012, 03:41 PM Thread Starter
Ive read that without the bellmouth the air rumbles to much into the airbox did you experience this. I am also now considering just pulling the snorkel out and putting the Polaris snowmoble bellmouth in instead many people here seem to think it gets the same effect as the Norman Hyde one.
post #4 of 11 (permalink) Old 10-25-2012, 04:51 PM
Main Motorcycle: 07 speedy
Other Motorcycle: 82 sportster
you can find a visual comparison between the polaris one and the "breathe" one below:
i'm pretty sure the "breathe" (why is it ALWAYS in quotes?) is slightly larger than the norman hyde unit. get more info about it here.
EDIT: a google image search for norman hyde bellmouth shows that the unit looks pretty restrictive (about the same as the polaris unit). if you don't want to eliminate the airbox altogether, the "breathe" unit is definitely the way to go. otherwise, i doubt the norman hyde is much better than the polaris. see?
steve0suprem0 is offline
post #5 of 11 (permalink) Old 10-25-2012, 05:19 PM Thread Starter
Yes I see the differnce. "Breath" does it fit the Speedmaster there website shows it is only for Bonnevilles and all it's sister bikes that breathe from the side under the cover. America and Speedmaster are under the seat. Does any one know for sure it fits on our cruiser america /speedmasters.
post #6 of 11 (permalink) Old 10-25-2012, 05:23 PM Thread Starter
Just noticed you own a Speedmaster Steve0Suprem0. So how do you like the "Breathe" and where did you put the large obd II plug.
post #7 of 11 (permalink) Old 10-25-2012, 06:26 PM
i don't actually have it, but that link i posted shows one installed in a cruiser. as far as the obd-ii plug, i haven't got one of those either since i'm carbbed. if it were me, though, i'd use my answer to everything: zip-ties.
post #8 of 11 (permalink) Old 11-08-2012, 11:58 PM Thread Starter
OK I went with the Polaris Bell Mouth fits easy enough a little cramped in there with the plastic cover on left and the plug housing on right. Changes the shape a little bit though.
ID:	56824   Click image for larger version
post #9 of 11 (permalink) Old 03-17-2014, 02:16 AM
Main Motorcycle: 2011 Thunderbird
SpeedBird, Where did you purchase the Polaris BellMouth from? Are you running a stock or aftermarket airfilter? Did you notice any performance or operational changes after pulling the stock snorkel and installing the bellmouth?
Caprock is offline
post #10 of 11 (permalink) Old 03-19-2014, 08:44 PM Thread Starter
I ordered it at Ronnie's mail order.com. I am running TOR'S long slash cut and a K & N air filter. It does make the engine a bit more throaty due to more than twice the airflow other than that no big change.
Bell Mouth Carburattors - Thruxton 900 jed Maintenance & Workshop Talk 2 07-29-2009 08:53 PM
Norman Hyde Bell End? DrEnglish Air Cooled Twins Technical Talk 3 03-23-2007 07:38 AM
Polaris "bell mouth" kliff Maintenance & Workshop Talk 2 08-09-2006 06:31 PM
Bell Mouth Not Enough.. 6449 Club Cafe' 20 06-06-2006 02:32 PM
