Helmet lock for an 09 SM/other questions - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comHonda Powersports
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 03-15-2010, 05:40 AM   #1 (permalink)
Finally pulled the trigger on an 09 Speedmaster 2 weeks ago. Loving it! 250 miles so far. Would be more but I have to work. Put the Triumph boards on it but had to have 2 weld spots per board applied to the underside to have them cant 5 degrees inward instead of canting outward. Weird set up for stock boards?? Going to add Rivco risers with round tops(item TS017 from newspeedmaster.com) Wish there was a helmet lock. Is there any way to add one? Or is it there and I dont see it? Also, any comments on chain lubes. What is good/bad? Any new comments on windshields? I read over and over the the Triumph Roadster shield has terrible buffeting. I am 5'11(shrinking). Any suggestions are welcome. Thanks
balduke is offline   Reply With Quote
Old 03-15-2010, 12:59 PM   #2 (permalink)
Favourite Bike: Tiger 1050
LennyT's Avatar
Other Motorcycle: All sold and kept Tiger
Nice choice, balduke. What colour did you get?
You can get a helmet lock from Fast eddy here:
http://www.fasteddysports.com/?page_id=3&category=7
If you scroll dowm, you'll see it.
This lock fits on the end of Kuryakyn grips which you would also need to purchase. Haven't got them myself, but it's an option. Hope you enjoy the Speedie.
Passion doesn't need an excuse.
LennyT is offline   Reply With Quote
Old 03-15-2010, 08:42 PM   #3 (permalink)
I know it sounds sort of ghetto, but many just slip the d-ring over the clutch or brake lever and use a small padlock. Necessity being the mother of invention I suppose.
'09 Speedy-19t front sprocket, BC Bomber Pipes,
Progressive Front Springs, Centerstand, 2" risers.
Pending-418HD Progressive rear shocks, ARK.
me1.0 is offline   Reply With Quote
Old 03-16-2010, 12:08 AM   #4 (permalink)
Favourite Bike: Speedmaster
I installed a set of BarEnder locks last year and really like them. I ended up buying the 6mm ones, then drilled and tapped the inserts. Saved me from having to spend even more getting new grips.
(stock photo)
For chain lube, I use Chain Wax.
RonL is offline   Reply With Quote
Old 03-16-2010, 04:34 AM   #5 (permalink)
Favourite Bike: 2005 Speedmaster
antman's Avatar
Other Motorcycle: Shanks pony
I do the same but without the padlock. Nobody touches another dude's helmet; it's a matter of honour.
antman is offline   Reply With Quote
Old 03-16-2010, 04:59 AM   #6 (permalink)
Thanks for the quick replies. I will look into all of them. BTW the Speedy is black/white. I like all the colors. Ride and smile.
Old 03-18-2010, 11:54 PM   #7 (permalink)
Favourite Bike: 2011 1200GS Triple Black
Woolly Bugger's Avatar
Other Motorcycle: 2014 Adventurer XC
Extra Motorcycle: '09 Speedmaster - sold
I've used a padlock attached to my seat rail. Not totally secure as the rail could be removed if someone was really determined. Works for me.
A picture is worth a thousand words, so what is the value of a picture?
A computer word is 16 bits. 2 bits = 1 quarter (25c). 1 bit is 12.5c. A word is worth $2, therefore a picture is worth $2,000. Eugene Volokh
Woolly Bugger is offline   Reply With Quote
Old 03-19-2010, 09:19 AM   #8 (permalink)
Favourite Bike: 2007 Triumph Speedmaster
erikmustride's Avatar
Other Motorcycle: 1972 Triumph Bonneville
Extra Motorcycle: Looking for a new one.
I use a cheap luggage lock (the kind you buy at Target or Wal-Mart 2 for $10) and loop it through the buckels on my helmet, and then the metal attachment from the throttle cable, then hang my helmet from my handle bars. Cheap. Easy. Well, mostly cheap.
"I have never killed a man, but, I have read many obituaries with great pleasure"--Clarence Darrow
"Not everybody likes us, but, we drive some folks wild"--Hank III
www.reinstatehank.org
www.rallyaroundthepits.com
erikmustride is offline   Reply With Quote
Old 03-20-2010, 05:26 AM   #9 (permalink)
Favourite Bike: mine
boofhead's Avatar
What if they dont know your "dude"
what goes round comes round
boofhead is offline   Reply With Quote
Old 03-21-2010, 06:23 PM   #10 (permalink)
Favourite Bike: '03 America
Other Motorcycle: '78 GS750 bobber
Extra Motorcycle: '79GS750 chop in progress
Disc lock u-lock works for the helmet too, with the added bonus of you won't forget to unlock your disc unless you're also in the habit of forgetting to put your helmet on. Pad lock is less clunky to carry than the u-style disc locks though. I generally use the hole in the left foot control to pad lock my helmet(if I remember to grab the lock on the way out the door).
Verde is offline   Reply With Quote
Helmet Lock - Where do you lock your helmet too? Gennaro Speed Triple Forum 12 05-19-2008 02:02 PM
Helmet Lock / Helmet Guardian daveysew Sprint Forum 2 05-25-2007 04:03 AM
Helmet lock? billybob235 Twins Technical Talk 10 01-17-2007 09:06 PM
Bolt Lock Helmet Lock? d2mini Twins Talk 13 04-07-2006 08:25 PM
Helmet lock? Leebo Sprint Forum 6 05-20-2005 03:09 PM
