Just bought and fitted this locking fuel cap on my 2009 Speedmaster. Triumph will tell you it won't fit, but I can tell you it does! It is a little awkward to remove because it sits flush with the tank. The stock item has a raised bit in the middle to grip when undoing, the locking cap does not, but it's easy enough, with a little down pressure to turn the cap and screw off. I think it looks nicer than the stock and of course it's lockable. Just thought I would share this info with you all.
That cap is sweet,im in Australia and cant seem to source one out here for my 2009 America.Could someone put me in the right direction,doesnt matter if its overseas.Cheers.
If your in Aus. Ring up or go to PETER STEVENS. they carry the fuel caps. If they don't have one near you they can order it. There is also a dealer in Shepparton that can get it for you. Ask for Tony. Their called AJs Motorcycles.
