Hi chaps,
So I bought a pair of rivco risers, and I should be fitting them this coming weekend, work and weather permitting (there's not much space in the garage).
I know it is trivial, but I am "alone" and I need to be sure and confident about the procedure before I set about to actually doing it.
By looking at the parts everything adds up except for the two "snap rings" (similar to these
) to put on the larger screws that will hold the risers to the upper steering head, as per the instructions. There's also a pair of washers for the same screws, so each screw will have one washer and one snap ring.
Question number one: what's the order? Is it riser, steering head, snap ring, washer and screw?
Question number two: what torquing specs should I use? the ones in the instruction sheet or the ones in the triumph service manual (for the OEM risers)?
QUestion number three: blue loctite on the buggers, yes or no?
Thanks in advance!
Pedro.
