how to remove fork shroud 07 TBA
Hi fellow riders, one of my upper fork shrouds has a dent in it, I want to remove it and tap out the dent. What is the best way to do this? It looks like I could loosen the triple clamps, undo brake caliper and speedo cable, and lower both forks at once and not have to remove the axle, wheel and fender? Or should I remove the wheel and fender and only lower the one fork (brake side) to remove the dented shroud?
Thanks!
-James
