Brake Issue - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.com Classifieds!SportbikeTrackGearNew Bonneville
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 02-23-2010, 11:06 AM   #1 (permalink)
Brake Issue
hi there,
i was playing around with my front brake the other day and stupidly pulled off a bit of rubber that seemed to hold the front brake in place. it's hard to explain but the photo below should be enough to help you understand. (indicated in green)
now i ultimately need to get this part back on the bike but can't force it back through. i believe i will need to take the brake off. i have managed to unscrew the top nut (in purple) however the one in red is way too tight to budge!
can anyone point me in the right direction to fix this?
thanks
ryancoleuk is offline   Reply With Quote
Old 02-24-2010, 06:47 PM   #2 (permalink)
Favourite Bike: The One I'm Ridin' !
mrt202's Avatar
You could try removing the bolt that you can get loose, then gently try to twist the caliper back and forth a bit while trying to loosen the other bolt. That bolt shouldn't be difficult to remove with a good fitting wrench...
mrt202 is offline   Reply With Quote
Old 02-25-2010, 07:31 AM   #3 (permalink)
Favourite Bike: 08 speedmaster
Crankry's Avatar
Hi try some penetrene on the stuck bolt let it soak while you polish those rims if nothing else the wheels will thank you for it crankry
Crankry is offline   Reply With Quote
Brake Issue CBadBoy Daytona Deliberations 5 08-03-2008 04:55 PM
Brake issue manalive Hinckley Classic Triples 4 04-09-2008 12:21 PM
brake pad issue daaman Speed Triple Forum 4 07-10-2007 06:10 PM
brake issue ricster Sprint Forum 8 03-03-2007 07:26 AM
That brake issue. . . RoadBuilder Speed Triple Forum 29 07-31-2006 06:59 AM
