| Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters |
02-01-2010, 08:13 AM
Detaching the tank ob 08 America
This might seem a stupid question to some of you but, I fitted the Triumph "Light Bar" at the weekend and had to remove the tanks, thats fine but as there is no fuel tap I left the tank connect at this point only, I did notice underneath what looked like a connector. Is this a connector containing a shut off perhaps or do you always have to drain the tank down first?
America - 08 EFi in Pacific Blue & New England White - Soon to be replaced by a 1050 Tiger in White!
02-01-2010, 08:34 AM
 Oops wrong forum, sorry guys.
02-01-2010, 08:37 AM
Aving a nighmare this morning, its just appeared in the right on now, it first appeared in the main Twins forum, ahhhh!
Anyway back to the original question now, over too you ....
02-02-2010, 05:54 AM
With the EFI's you have a fuel pump in the tank so you will not have a on/off tap. Just unplug the fuel hose at that connector you are talking about and that is all there is to it.
Cheers,
John
02-02-2010, 05:58 AM
SuperStock Favourite Bike: mine
Why did you have to remove the tank to fit the light bar
what goes round comes round
02-02-2010, 08:52 AM
You have to run the wiring harness provided in the kit under the tank, also there is a connector under there you have find as well as fitting the relay.
02-02-2010, 08:53 AM
Cheers,
John
Thanks Wolf Dreaming, so no leak then, life is good
02-02-2010, 10:59 AM
Super Sidecars Favourite Bike: Love the one yer with!!
Posts: 60 Other Motorcycle: 09 America
I found that you have only to lift the tank up a bit, with the help of another, the light connections slide right onto the medal holder on the right hand side and the wires plug in without problem. make sure you have not pulled out the breather tube under the tank,,
02-02-2010, 04:51 PM
Thanks mate ...I only asked because i just fitted a Rivco light Bar and did not have to remove the tank , all wired up outside
