It'd be some work to get it to fit. Listed after all the specific HD stuff it fits, it says
"Most applications that accept a standard H-D style backrest with 8-3⁄4” wide mounting position. The mounting holes are 1-1⁄4” center to center with 1⁄4” -20 tapped threads."
Based on the width of the fender, you'd have to build brackets that step in a bit on each side to fit the width.
