2009 america:
undo the allen bolts holding the dash down, pull it to one side, pop the triumph plastic badge out, slide the tacho wire through the hole, plug it into the connector (there's only one that will fit) attach the tacho to the little plastic bracket underneath, line it up so its straight, put the dash back over the holes, screw the allen screws back in, job done
for ease of use you can take the whole dash off by unclipping the wire cluster. makes things a little easier
definitely don't need to take the whole tank off. unless he was meaning take the tank console off, or take the dash off the tank. don't know. but yeah its very simple and you can do it no worries
that's what's called "marketing" I suppose
sounds more to me like the dealer trying to get you to take it in so he can fit it in 5 mins and charge you an hours labour :P
