Changing Fork Springs Question - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!New BonnevilleOntario TourismMotorcycle.comSportbikeTrackGear
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 01-04-2010, 04:14 PM   #1 (permalink)
Favourite Bike: 2008 Honda Goldwing
Other Motorcycle: 2010 Triumph Thunderbird
Extra Motorcycle: 2005 Triumph America
I am going to be changing the fork springs on a 2005 America in a few weeks and was wondering if anyone can tell me if the pinch bolts in the top yoke need to be loosen to remove the fork caps?
Can't really tell from the service manual, of course the manual wants you to remove the entire fork to change the springs, but I will be leaving them on the bike.
I've done some bikes in the past where it was necessary and some where it's not.
Thanks, Roy
RoyH is offline   Reply With Quote
Old 01-05-2010, 11:30 AM   #2 (permalink)
Favourite Bike: 2006 Speedmaster
I put my bike on a lift, to unload the front end. I loosened the top pintch bolt then took off the top cap...not sure if I had to loosened the top pintch bolt..The springs are under compression when you take the top cap off so go slow when removing it
jimg010 is offline   Reply With Quote
Old 01-05-2010, 07:52 PM   #3 (permalink)
B02S4's Avatar
Yes, loosen the top pinch bolt before removing the top cap.
B02S4 is online now   Reply With Quote
Old 01-10-2010, 01:56 PM   #4 (permalink)
Favourite Bike: 07 Speedmaster, Mulberry
SMJoe's Avatar
Would one have to do the same for 07 Speedmaster that is in the works for this Spring?
SMJoe is offline   Reply With Quote
Old 01-10-2010, 03:06 PM   #5 (permalink)
B02S4's Avatar
Originally Posted by SMJoe View Post
...same for 07 Speedmaster...?
Yes...
Old 01-26-2010, 02:31 PM   #6 (permalink)
Favourite Bike: The One I'm Ridin' !
mrt202's Avatar
I've never had to loosen the top pinch bolts to get the caps off...
mrt202 is offline   Reply With Quote
Old 01-26-2010, 07:17 PM   #7 (permalink)
B02S4's Avatar
How tight are they now, & how far up is the fork tube above the top tree?
Old 02-02-2010, 06:16 PM   #8 (permalink)
mrt202's Avatar
How tight are what?
Per Haynes Manual, top yoke clamp bolts= 20Nm, and fork top bolt (cap)= 23Nm.
My fork tubes are flush with the top yoke. Does that help?
Changing fork springs and oil bobh Trophy 14 03-26-2011 09:18 AM
? about changing the fork springs bikerdrumr Twins Technical Talk 11 08-20-2009 10:34 AM
Changing fork springs rat2tymes Trophy 5 03-17-2009 05:02 PM
Changing Fork Springs tham Twins Technical Talk 24 12-06-2006 05:17 AM
Changing Fork Springs tham Club Cafe' 16 09-15-2006 05:11 PM
