Progressive Lowered Fork Springs - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
post #11 of 21 (permalink) Old 03-11-2010, 08:08 PM
Main Motorcycle: 2015 Tiger XRT
Woolly Bugger's Avatar
Other Motorcycle: 2011 1200GS Triple Black
Originally Posted by cmac View Post
I installed the 12” 412’s on the rear and purchased the Progressive front lowering spring kit but I just installed the progressive springs a slid the tubes up 3/8” in the tree’s. I was nervous about removing the damper rod and installing the lowering springs. It looks and rides fine but I would like to install the lowering springs one day. I hope you do step-by-step on the front.
Looks like an 09/10 Speedy? What mirrors do you have on there my friend?
A picture is worth a thousand words, so what is the value of a picture?
A computer word is 16 bits. 2 bits = 1 quarter (25c). 1 bit is 12.5c. A word is worth $2, therefore a picture is worth $2,000. Eugene Volokh
Woolly Bugger is offline
post #12 of 21 (permalink) Old 03-11-2010, 08:14 PM
Main Motorcycle: 2012 Thruxton
cmac's Avatar
Other Motorcycle: 1969 Bonneville T120
Extra Motorcycle: 2016 Streetglide
Originally Posted by rockDAWG View Post
Did you get 1/2 inches drop in the sitting height?
It lowered it by ¾” in the rear and about a ½” of an inch in the front.
cmac is online now
post #13 of 21 (permalink) Old 03-11-2010, 08:21 PM
cmac's Avatar
Those are the Triumph teardrop mirrors. I am very happy with the overall quality of them but they do tend to vibrate more than the stock lollipops.
cmac is online now
post #14 of 21 (permalink) Old 03-12-2010, 03:45 AM
Main Motorcycle: 2005 Speedmaster
antman's Avatar
Other Motorcycle: Shanks pony
If the Ricor Intiminators are the duck's danglies like I keep reading, why do people continue to install progressive rate springs and the like? Just wondering if there's a particular reason.
antman is offline
post #15 of 21 (permalink) Old 03-12-2010, 01:21 PM
Main Motorcycle: 2008 Honda Goldwing
Other Motorcycle: 2010 Triumph Thunderbird
Extra Motorcycle: 2005 Triumph America
Fair question, my persoanl thoughts/reason for this project.
First is to understand this thread is primarily about replacing front springs to 'lower' the bike not necessarily to improve suspension. So even if the intiminators were part of the project the springs would still be replaced. And the Progressive lowering kit 'should' improve the suspension.
For me the main reason for this project is to lower my wife's bike so she can be more 'flat-footed' on the bike as she is haven't some major slow speed issues handling the bike. So we are lowering the rear with some Progressive 412's so we need to also lower the front, thus new lowering kit with new springs.
While I also what the best bag for the buck I know the Progressive shocks and springs will improve the suspension. I also looked at doing the Ricor's at the same time. BUT the Ricor's (off the top of my head) are about $300! After already spending about $350 for the shocks and lowering kit another $300 wasn't going to happen.
My wife doesn't need a 'racing' suspension setup, the bike will be lower, and we will see overal suspension improvement both front and rear for about the same price as the Ricor's alone.
RoyH is offline
post #16 of 21 (permalink) Old 03-15-2010, 05:42 PM
Main Motorcycle: Speedmaster 2004
Just order a pair of the 11.5" Progressive 412, Hope it will get here this week for installation this weekend.
rockDAWG is offline
post #17 of 21 (permalink) Old 03-15-2010, 06:37 PM
padwah's Avatar
i lowered my 05 speedy at the back, from 12.5 inch to 11.5 inch, with hagon nitro shocks. hagon make them to your exact weight and if you ride 2 up or carry a lot of luggage , they also take into account the kit you wear. i ordered them on a friday and they where delivered to my door the following wed mornin. perfect. 15 dampin settings and preload is an adjustable thread at the top which turns down until your basically happy. as with the progressive fork springs. i installed the 1 inch lowering kit. i had so much trouble trying to get the bottom spring retaining bolt out. you need a electric ratchet or air wrench and a brush sahft wedged down the tube. you only get one go or else it just spins forever. end result?. they lowered the front end, but really thats about it. they are still as spongy as ever at the front end. i just touch the front brake and the bike dives. so im not sure what to do to sort that out. thicker oil is a no go as it just defeats the purpose, so if anyone with any ideas, let me know. ps money is tight lol tks
padwah is offline
post #18 of 21 (permalink) Old 03-19-2010, 01:38 PM
Shocks and Lowering Springs Update (Kinda Long)
Might post some pictures later, but here's the results of this project...
Got the 11.5" shocks and front springs with 1" drop (more on this later) installed and rode the America to work yesterday with new configuration. Ride impression later in post.
Rear shocks took all of about 20 minutes to install with no issues at all. With just the rear shocks seat height was about 1 1/2" lower. But of course front end was still the same height so overall feel of the bike was even more chopper like. Not what we wanted!
Removal of front forks took about 30 minutes and was easier than I expected. Now the hard part, removal of the damper rod bolt to remove the damper rod. I had researched this extensively for the last few weeks and had all the tools and tricks I had learn via the internet ready to go.
Got the first fork setup in the vise put a 6" long allen socket on the impact wrench and gave it a go. Damper bolt and rod both just spin!
Ok, let's try the dowel/broom stick trick to keep the damper rod from spinning. Tapered a 1" dowel I had and stuck down the fork tube into the damper rod. Still a no go, bolt would not break loose.
Put the fork back together and compress the spring to see if this would hold the damper rod enough to free the bolt. Nope!
Try various other attempts over the next hour or so but that damper bolt would not bulge. Make the decision to take the forks to the dealer and have them free the bolt and install the kit with a 2" drop in front to level the bike as indicated by Progressive tech support.
Dropped them off on Saturday and they were going to do them on Tuesday morning. Got a call about mid-morning from the dealer with bad news. Even they could not get the bolt to break loose!
They were going to have to drill out the bolts and replace with new bolts and get them torque properly when reinstalled. BUT, they didn't have any bolts in stock and neither did Triumph America, would have to order bolts from UK, 7 to 10 days to arrive. Oh well, authorize the work and resigned to waiting for up to 2 week to get bike back together.
Mid-afternoon Tuesday got another call from dealer forks were ready to be picked up! They tried again before drilling out the bolts and were able to get the bolts loose.
Picked forks up Tuesday evening and would install on Wednesday. Take a look in the box the springs came in and what the...
There were still 2 damper rod springs in the box and for a 2" drop as I requested there should not have been any damper rod springs left!
Talked to the dealer on Wednesday morning and sure enough they didn't read the instructions correctly and just removed the stock damper rod spring and put two Progressive damper rod springs on instead of putting the two springs on IN ADDITION to the stock spring. Confirmed with the dealer that they did however put the correct length spacer in for a 2" drop. So now I have forks with spring for a 1" drop but the spacer length for a 2" drop. Dealer was very sorry and wanted to make it right.
However, before taking the shocks back in I called Progressive and discussed the issue and they indicated that the shorter than recommended spacer was not really a problem. Front damping would just be a bit on the 'soft' side and front would set just a small amount lower.
So it was decided to reinstall the forks just to see how this combination would be. Happy to say height of bike was just perfect for my wife and front end of bike was now sitting just about perfectly level.
So with dealer's approval and commitment to still fix if we wanted after getting a few miles on the bike we have decided to not have the 2" drop installed.
Ride Impression:
First off remember this is my wife's bike...
Installation has lower the bike an average of 1 1/2" at all points on the bike that I measured. This now allows my wife to flat foot the bike.
Rode around the block a few times Wednesday evening and initial impression was very good. Bike rode much better in my opinion with the front end lowering. Ground clearance definitely affected and I was able to bottom out the front with hard braking over a bump.
Rode to work on Thursday (7 miles city streets) and confirmed that I really like the ride and handling better with the lowering front end.
However, I do feel the front end is too 'soft' and I think I will put a longer spacer in. But this is not something that I will do right away. I weight just a bit more than the wife so I think I'll let her get some miles on it first.
Overall very pleased with the results but will caution for anyone doing this ground clearance will be affected so be careful.
RoyH is offline
post #19 of 21 (permalink) Old 12-09-2012, 10:59 AM
Main Motorcycle: 2009 Triumph America
Other Motorcycle: Virago 250 - Kid trainer
Change out or cut OEM spring collar
New here. Thanks a million to everyone who have previously done all the testing, design and research. I was looking at the Bandit "OEM Parts - Triumph America 2009" parts break-out. I need to lower the front about an inch to level it up (on my '09 Amer). Could I replace the OEM collar shown in the pic with some PVC?
Dallas09America is offline
post #20 of 21 (permalink) Old 12-09-2012, 12:02 PM
Main Motorcycle: Bonneville America
grzegorz's Avatar
Other Motorcycle: 2001 Bonneville Custom
yes you can but cutting spacer is not a solution
grzegorz is offline
Progressive Fork Springs Johnww Air Cooled Twins Technical Talk 2 03-08-2009 10:34 PM
Progressive fork springs? Slinky Hinckley Classic Triples 30 02-14-2009 07:00 AM
Cheap progressive springs fork springs uzidzit Air Cooled Twins Technical Talk 2 03-26-2008 01:26 AM
Progressive Fork Springs wonderdog Air Cooled Twins Technical Talk 2 02-05-2007 10:20 AM
Progressive fork springs Hilts Air Cooled Twins Technical Talk 5 12-07-2006 09:54 PM
