British Motorcycle GearTriumph DetroitMotorcycle.comOPP RacingSoupy's PerformanceMotorcycle.com Classifieds!
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Penn Foster
Old 11-04-2009, 10:07 PM   #1 (permalink)
Favourite Bike: My 2007 America
Other Motorcycle: none....yet
HELP. Small oil leak
Fellow Rats
My 07 America, has finally rolled over 7000 mi. and I have a small oil leak comming from what appears to be the gasket between the cylinder head and the valve cover. I am curious to know if anybody else has had this happen and is it possible to change the gasket without too much of a headache.
Thanks
pelicanboom
Pelican Boom is offline   Reply With Quote
Old 11-05-2009, 03:35 AM   #2 (permalink)
Favourite Bike: split between the two
Other Motorcycle: 1952 Sunbeam S7 de-luxe
It's not difficult. Tank off plus remove SAIS control valve with hoses and pipes if fitted, and then after removing the fasteners it's fiddly to manoeuvre the cover out of the way. Use a new rubber gasket and the most inportant thing is to ensure you torque down to the correct spec, DO NOT over tighten or your world may end before 2012. 10nm, 7.37561ft/lb.
The 0.00001ft/lb is the clincher.
John
the trouble with the world today is apathy;
But I don't care.
johntog is offline   Reply With Quote
Old 11-05-2009, 05:55 AM   #3 (permalink)
Favourite Bike: Speedmaster efi
eagle's Avatar
Other Motorcycle: '75 Bonneville T140V
I had a T100 that leaked like that. Before struggling to get the cover off and replace the rubber gasket it might be worth checking the bolts are torqued up enough. Mine weren't. Tightening them to the right torque stopped the leak permanently.
Alternatively you could view the oil leak as an optional extra - making your bike more retro and authentic! See it as a badge of honour?
Always forgive your enemies,
Nothing annoys them more
eagle is offline   Reply With Quote
Old 11-05-2009, 08:05 AM   #4 (permalink)
Eagle...I was having that same exact thought also because its only on one side of the engine.
John...Thanks for the insight. I already have a new gasket, so will give that a go, Thanks mate, Cheers!
Old 11-05-2009, 11:21 AM   #5 (permalink)
Favourite Bike: 05 Black Speedmaster
Unless damaged you can probably reuse the gasket BUT you should change the rubber washers that actually provide the pressure for sealing the cover. The bolts do not tighten, they bottom out.
Old 11-05-2009, 11:42 AM   #6 (permalink)
eagle's Avatar
Mine were only hand tight - must have been a Friday special!
small oil leak on my 955 HoyaXC07 Sprint Forum 9 08-05-2009 07:56 AM
small oil leak bass-33 Twins Technical Talk 9 03-05-2008 07:54 AM
small oil leak trav13 Twins Technical Talk 1 10-09-2007 01:13 AM
Small oil leak jcline8 Twins Technical Talk 2 07-03-2007 11:28 PM
small oil leak Triple_Rider Speed Triple Forum 4 10-27-2006 12:28 PM
