» Links |
| Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters |
11-04-2009, 07:53 PM
SuperStock Favourite Bike: 07 Speedmaster/Mulberry
Speedmaster Speedometer saga
In the middle of this last summer, I submitted a post about my speedometer on my 07 Speedmaster. When cold or sitting for about a half hour it would go wild on takeoff. At 15 mph, the needle would indicate 40 or 50 mpg. If I got it up to around 50 (per my GPS), the needle would fly all the way around and peg on the zero.
No one else seemed to have had the problem or at least there were no replays from similarly afflicted bikes.
Stopped at the dealer and got some got a diagnosis that this was just a start-up test procedure. To which I commented to didn’t do it the first 6000 miles. Once we got past that, he suggested I remove the cable and re-install it and that should clear the problem.
My feeling was it wouldn’t help. Since this is just a mechanical process, I couldn’t see any way it would make the indicated speed jump to over double the real speed. But I did it, it was no help.
Back to the dealer. They took it in the shop and pulled the cable, put it back on and went for a rest ride. They then reported the cable was “chewed up” on the wheel end. I still couldn’t see how that would increase indicated speed but who am I.
They were nice enough to order a new cable for me (not under warranty, 30 bucks). Ten days later, it’s in and I ‘m back wrenching (OK, not a big job). I compared the old and new side by side and would be hard pressed top tell the old from the new if one wasn’t clean and the other dirty. No evidence of the cable being “chewed up”.
Of course, it still did exactly the same thing.
Back to the dealer. Submitted a warranty claim to Triumph and a fortnight later it was in and ready for install. Had to wait a week for an appointment but finally got it installed (about 3 minutes before my warrant expired).
Works great now, although the odometer now reads 51 miles instead of 7700. The new on is a little better then the old one, it was usually about 10% fast. The new one is only about 7 % fast.
11-05-2009, 09:35 AM
Minitwins Favourite Bike: Triumph Speedmaster 09
Posts: 18 Other Motorcycle: Triumph Speed Triple 1050
Has anyone else found that their speedo measures fast...I only say so as i went thro a speed trap at 70 mph in a 60 mph limit and havnt heard anything.....maybe I wasnt going 70 after all  ...fingers crossed
11-05-2009, 05:19 PM
Supersport 400 Favourite Bike: 05 America
Posts: 90 Other Motorcycle: I wish Extra Motorcycle: another wish
They all read fast , putting a 110/90/18 Tyre on the front fixes that
what goes round comes round
11-05-2009, 06:28 PM
SuperStock Favourite Bike: 1954 Tiger 110
Posts: 265 Other Motorcycle: 2004 Speedmaster
I checked mine with a handheld GPS and it read about 5% fast.
Maybe allowing for your speedo reading fast and the little bit of tolerance they allow at radar traps you might be OK.
 I used to be paranoid, now I think they are out to get me
Grow old disgracefully and be an embarassment to your kids..
Staintune Exhaust, AI Removed, Main Jet (No Idea)
11-05-2009, 11:03 PM
Grand Prix 125 Favourite Bike: 2009 Speedmaster
My speedometer is exactly 10% fast, but my odometer seems dead on.
11-10-2009, 04:29 AM
I had the exact same speedo problem as you HumpedZebra. There have been a few threads about them over the years.
According to my speedo I had the worlds fastest air cooled twin cylinder bike, eat your heart out Anthony Hopkins.
11-10-2009, 04:35 AM
Oh and BTW HumpedZebra it proves your dealer is an ASS
How can the speedo cable suddenly turn 20 times faster, then return to normal ....
It had to be an internal fault of the speedometer.
11-16-2009, 12:48 AM
Minitwins Favourite Bike: 2004 Tiger
Posts: 19 Other Motorcycle: 2002 America Extra Motorcycle: 1983 Suzuki Gsx 250
Speedo
I also have the same problem with my speedo goes all the way to the stop when I'm only doing about 60klm. I generally let it sit there for a while than give it a tap with my fist and then it comes back to something reassembling normal gives me the ****s but it works.
Ben.
Ben.
2002 America, 2004 Tiger
12-05-2009, 03:35 AM
Site Supporter Super Sidecars Favourite Bike: Speedmaster
Posts: 65 Other Motorcycle: Yamaha V-Star
I am having a different, but related issue. Took delivery of my bike today, finally, after a major fight with the dealer. Put 30 miles on the bike around town and discovered the speedo doesn't work. It only goes as high as 20 mph, even when I'm doing 60.
Back to the dealer tomorrow!
2010 Speedmaster NE White/PH Black
12-14-2009, 12:25 PM
I'm jumping in to this a little late, however, I have an '03 Speedmaster. It's been great up until about a year ago (12,000 miles then), when I noticed that the Speedo Needle would go all the way around the dial, at just 10mph.
Very similar to the tale that you tell. At any rate, with a tap on the speedo, or after running the bike for a while, it would always sort itself out. It also didn't happen every time, but was more likely to happen in sub 40 degree whether.
I originally put it down to a quaint little nuance of the bike. Well, in August this year, the speedo needle stopped responding...as had the trip meter. The odometer though, kept working. This led me to believe that it was likely NOT the cable, but I did go ahead and order/install a new $30 cable. It was a surprisingly easy install.
I jumped on the bike and felt very proud of myself that everything was working great now. I thought I'd just saved $270 on having to buy a new speedometer. Two days later (38 degrees), I was about to go for a ride...and the speedometer spun around again (but at least the trip meter is still working).
At any rate, I am back to square one. I'm going to try some graphite grease in the gears and see if that helps. If not, I think I'm going to have to invest in a new speedometer.
Such is life.
Daren
