Headlight glass replacement - Triumph Forum: Triumph Rat Motorcycle Forums
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 10-18-2009, 05:42 PM   #1 (permalink)
Favourite Bike: Rocket Roadster
Binnsy's Avatar
Other Motorcycle: T/bird gone
Extra Motorcycle: Speedy gone
Thumbs up Headlight glass replacement
Last weekend i got a stone through my headlight and it was in pretty bad shape. Still worked but it was only a matter of time before it would fall apart as it was only held in place by the sealant around the perimeter. So off to the Triumph shop I go, expecting to shed a few bucks and walk away with a new glass. Holy Carp! A$395.00 + A$15.00 for a courier to fly one over from Melbourne. Unfortunately this seemed a bit steep and after a short vent I walked away without one.
Decided to pull the headlight out of the shell and search for one to suit. First stop was a market where there were a lot of headlights but nothing even close. Second stop AutoBarn and after about 10 minutes found one that was pretty close. It was a "Hansa" brand sealed beam 7" unit that was a bit longer, chunkier profile but at A$13.00, was worth a shot. Bought the unit and headed home.
At home I spent about 10 minutes fiddling to get the chunkier headlight into the shell. It wasn't a perfect fit but seems to be solid in the frame and the clips just fit on with a little persuasion. Flicked the power on and voila! worked fine. Haven't tried it out at night yet but it seemed to have a reasonable pattern and high and low beams are where they should be so fingers crossed.
For a saving of A$397.00 I think I will tolerate a minor difference in the profile.... I will let you know how it is at night after I have tried it, hopefully it will be OK as the rating was similar.
Scientists say too much alcohol damages your memory, I forget why...
Binnsy is offline   Reply With Quote
Old 10-19-2009, 04:57 AM   #2 (permalink)
Favourite Bike: 2009 Speedmaster
aceuggy's Avatar
That's bad luck Binnsy, but at least you seem to have got it sorted for not too much dosh. Think I might invest in one of these headlight protectors. Could save me from a big bill. http://cgi.ebay.co.uk/TRIUMPH-AMERIC...item53dd40e97a
That's what I'm talkin' about!
aceuggy is offline   Reply With Quote
Old 10-19-2009, 04:58 PM   #3 (permalink)
Binnsy's Avatar
Yeah, in retrospect I wish I'd had one, parts are pretty pricey over here..
On a good note I took it round the block last night to see if it was OK. The pattern is wider and not as defined as the genuine but certainly good enough for normal circumstances. In fact on the winding mountain roads the wider pattern would be beneficial to see around the bends....
Regards........Binnsy
Old 10-24-2009, 06:25 PM   #4 (permalink)
Favourite Bike: 2011 1200GS Triple Black
Woolly Bugger's Avatar
Other Motorcycle: 2014 Adventurer XC
Extra Motorcycle: '09 Speedmaster - sold
Umm, so all headlights are not created equal. Shows how much I know
There is a thread on replacement headlights, albeit for Bonneville at http://www.triumphrat.net/twins-tech...ml#post1387252. Not sure if this is of any use.
A picture is worth a thousand words, so what is the value of a picture?
A computer word is 16 bits. 2 bits = 1 quarter (25c). 1 bit is 12.5c. A word is worth $2, therefore a picture is worth $2,000. Eugene Volokh
Woolly Bugger is offline   Reply With Quote
Old 10-25-2009, 03:39 AM   #5 (permalink)
Hey Binnsy.
Check out the Western Plains Triumph site ( au ). A Kiwi ( Abbo, go figure that one ) has a possible solution for ya.
Kiwi Tiger is offline   Reply With Quote
Old 10-25-2009, 05:07 PM   #6 (permalink)
Binnsy's Avatar
Originally Posted by Kiwi Tiger View Post
Hey Binnsy.
All is good thanks, took the bike & $A13.00 headlight out for a spin last night, great result. The beam has a main spot straight up the road and a closer wide pattern that fans out on both sides of the main spot. I think it is actually better than the genuine, I felt I could see a lot more with this light, go figure...
Broken Headlight glass...where can i get a replacement? sbpark Twins Technical Talk 32 05-14-2010 04:33 AM
2002 bonneville headlight glass stupidroy RAT - Australia 3 09-22-2009 09:04 PM
Broken Headlight Glass Speedy Russ Speed Triple Forum 7 09-21-2009 08:18 PM
Replacement glass for oval mirrors Tenover Twins Technical Talk 6 07-31-2006 11:16 AM
