Lubing Speedmaster chain - Triumph Forum: Triumph Rat Motorcycle Forums
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 10-12-2009, 02:27 PM   #1 (permalink)
Favourite Bike: 2009 Speedmaster
aceuggy's Avatar
What do you guys use to lift the rear wheel on your Speedy in order to lube the chain?
That's what I'm talkin' about!
aceuggy is offline   Reply With Quote
Old 10-12-2009, 06:28 PM   #2 (permalink)
Favourite Bike: Thruxton
With the bike on its side stand and front wheel all the way left, I put a floor jack under the tab where the center stand would be [if I had one] and raise a bit until the wheel clears the floor.
davidc is offline   Reply With Quote
Old 10-12-2009, 08:16 PM   #3 (permalink)
Favourite Bike: Speedmaster
I picked up a motorcycle lift from Craftsman, on sale, with Craftsman Club discount, it came to $80. Makes lubing the chain, cleaning the bike, and checking tires, nuts, & bolts very easy.
RonL is offline   Reply With Quote
Old 10-12-2009, 08:41 PM   #4 (permalink)
Favourite Bike: '08 Tiger ABS
Other Motorcycle: formerly '07 Speedmaster
When I had my Speedy, I used this.
http://www.heindlengineering.com/
Probably too heavy to ship, but works great and nothing to go wrong with it.
mgtbeck49 is offline   Reply With Quote
Old 10-12-2009, 10:54 PM   #5 (permalink)
B02S4's Avatar
Rivco centerstand:
http://www.fasteddysports.com/?page_id=3&category=11
B02S4 is offline   Reply With Quote
Old 10-13-2009, 12:19 AM   #6 (permalink)
Originally Posted by B02S4 View Post
+1 but I got mine from newspeedmaster.com. Great product.
Speedy Dave is offline   Reply With Quote
Old 10-13-2009, 12:50 AM   #7 (permalink)
Homemade Bike lift
Made one out of 2x8x8, 3/4"x4' pipe w/flange. Cut the 2x8x8 in half. glue the two halves together. Then bolt them with carrige bolts at the ends (counter sink the bolts so they are flush).
On the bottom of your two attached boards, counter sink the flange with edge of the flange centered and about 3 1/2 inches from one of the ends. This is done to make the flange flush with the bottom of the glued boards. I used wood chisels and a dremel to do this work. This is the hardest part (tedious actually, not hard) of the build.
In the center, drill a 3/4 in hole at the center of one end about 4 inches from the end. Run pipe through, attach to flange, pull pipe and flange back up through the wood and screw the flange to the bottom of the boards. If you did this correctly the flange (and screws) will be flush at the bottom. You're done.
To lift bike, run the board under the bike just rearwards of the oil filter. Align with the frame. I do this from the clutch side. Pipe is now sticking straight up on the clutch side of the bike. You need to make sure the pipe will clear the handle bars in this next move.
Now roll the pipe forward and down, the wood comes up and your rear is lifted off the ground about a 1/2". Can be built for free with odd materials laying around or for about $15 from the local hardware store. If you have a peice of 4x8 laying around you can skip the cutting and gluing phase.
Great on the riding mower as well.
'09 America
Pacific Blue & White
Buckhorn handlebars, windscreen, soft bags, tool bag, short TORs (slash) exhaust.
FeHorse is offline   Reply With Quote
Old 10-13-2009, 12:51 PM   #8 (permalink)
Favourite Bike: 05 Black Speedmaster
Like Fehorse I use the wood and pipe (not as fancy a build) and it will also lift the front wheel.
Old 10-13-2009, 05:26 PM   #9 (permalink)
Favourite Bike: Rocket Roadster
Binnsy's Avatar
Other Motorcycle: T/bird gone
Extra Motorcycle: Speedy gone
Thumbs up
I bought an ATV lift from Repco for A$199.00. Lifts the bike totally off the floor about 300mm so any maintenance is much easier. It has hooks for tying down the bike and outrigger casters for stability. Very good investment.
Similar to this: http://www.chinamachinerymanufacture...VLift_7399.jpg
Scientists say too much alcohol damages your memory, I forget why...
Binnsy is offline   Reply With Quote
Old 10-14-2009, 02:37 PM   #10 (permalink)
aceuggy's Avatar
Thanks for the feedback guys. I have seen this now. Anyone know anything about it? Looks pretty useful to me. http://cgi.ebay.co.uk/Triumph-Worksh...d=p3286.c0.m14
I don't understand lubing the chain Dale_K Twins Technical Talk 42 08-17-2008 08:32 AM
procedure for lubing your chain? redl1nerpm Triumph SuperSports 6 07-16-2007 12:21 AM
Bonnie wheels, spokes issue and chain lubing? sponger Twins Technical Talk 6 06-05-2007 12:00 AM
Chain lubing - how often REALLY? trumppa Speed Triple Forum 21 08-31-2006 09:01 PM
Speedmaster chain guard damboy Twins Talk 7 10-26-2005 04:19 PM
