Saddlemen Teardrop bags? - Triumph Forum: Triumph Rat Motorcycle Forums
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 10-10-2009, 08:23 PM   #1 (permalink)
Favourite Bike: 2009 Triumph Speedmaster
I've seen several photos/threads from folks with the Saddlemen Drifter and Drifter Slant bags, but I haven't seen any with the Teardrop bags on an America/Speedmaster. With the cutout for the rear shock, it appears that the Jumbo-sized bags should fit without any issues. Just wondering if anyone has any insight before I order. [LINK]
jwalcik is offline   Reply With Quote
Old 10-23-2009, 06:35 PM   #2 (permalink)
To answer my own question, the Jumbo bags fit quite nicely. I had to trim the bags a bit to get them to work with the easy brackets, but an altogether painless install.
Old 10-23-2009, 08:51 PM   #3 (permalink)
Favourite Bike: 2009 Bonneville America
TriumphLance's Avatar
Other Motorcycle: 2011 Harley Street Bob
jwalcik - looks great!
When you say you had to trim the bags, where did you have to trim?
TriumphLance is offline   Reply With Quote
Old 10-24-2009, 12:34 AM   #4 (permalink)
The bags come tied together with a yoke that has zip-off disconnects for each bag. It also comes with a set of "universal" brackets to keep the bags out of your suspension/chain/rear wheel. Universal means "Harley Davidson" (at least the bolts the kit comes with does, you could probably drill the holes out and get your own metric replacements).
There are four screws that hold the saddlebag side of the zipper on. I removed all four. I used a drill to bore out the 2nd and 4th holes. They lined up perfectly with the top two bolt holes in the easy brackets. I then marked and drilled holes for the lower two bolts.
With the "cruis'in" style bags, the saddlebags open back to front. There is a small plastic buckle in the back that you turn, and then the bags open towards the front of the bike. On the bike-side of bags, the lid overlaps a fair amount in the front (2-3"), along the side (1 1/2"), and then again in the very back (3"). The back is where I had problems. The deep flap was pushed up against the back of the easy bracket. I had to trim it up near the back so that the overhang followed the 1 1/2" arc along the rest of the bag. The part that needs to be trimmed is very clear once you have the brackets and bags bolted together.
Does that make sense? If not I can get some pictures when it's light out.
Old 10-24-2009, 01:10 AM   #5 (permalink)
Thanks for the explanation! Again, the bags look real nice on your bike! They are a great match curvature-wise with your seat and fender.
Old 10-24-2009, 01:13 AM   #6 (permalink)
Not a problem at all, and thanks! I'm definitely happy with the way the bags follow the shape of the fender.
Anybody use Saddlemen Universal Saddlebag Support Brackets? louzilla Twins Talk 0 06-24-2009 07:53 PM
Predators with Triumph teardrop bags Chainsawd Twins Technical Talk 2 06-11-2008 05:06 PM
wanted saddlemen bag pics on Bonneville/T100 cobblepot Twins Talk 0 04-17-2006 11:27 PM
Teardrop silencers on Ebay (UK) cal6n Twins Talk 5 07-25-2005 02:50 PM
Will Saddlemen saddlebags fit an Adventurer? Msullivan Hinckley Classic Triples 3 10-09-2004 03:10 PM
