Mirror Vibration - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleHonda Powersports SportbikeTrackGear
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 09-22-2009, 10:40 PM   #1 (permalink)
Mirror Vibration
I just replaced the stock mirrors on my 09 America with the Triumph Teardrop Mirrors. They went on without any real problems but the left mirror vibrates so bad that I can barely use it. Is there anything I can do to reduce or stop the vibration in the mirror. I really like the look of them especially the wide field of view.
CCSO3932 is offline   Reply With Quote
Old 09-25-2009, 12:32 AM   #2 (permalink)
Favourite Bike: Rocket Roadster
Binnsy's Avatar
Other Motorcycle: T/bird gone
Extra Motorcycle: Speedy gone
Try this: http://www.barsnake.com/
Scientists say too much alcohol damages your memory, I forget why...
Binnsy is offline   Reply With Quote
Old 09-25-2009, 10:09 AM   #3 (permalink)
Favourite Bike: Speedmaster
Not sure about the America, but my 09 Speedmaster has plugs in the bars to hold on the end caps. You can't slide anything into the bar. You'd have to get rid of those plugs to use the BarSnake and then figure out a different means to attaching end plugs.
FWIW, I've read somewhere that the Triumph mirrors do vibrate more than the stock round ones.
RonL is offline   Reply With Quote
Old 09-25-2009, 11:23 PM   #4 (permalink)
Favourite Bike: My 09 America
There is a liquid barsnake you could possibly pour in through the holes that are used for the wiring clips
When injustice becomes law. Resistance becomes duty.
jimmy4871 is offline   Reply With Quote
Old 09-26-2009, 12:45 AM   #5 (permalink)
cmac's Avatar
Did you install the new tolerance rings and make sure the mirror stem is fully inserted? When I installed my new mirrors I had the same problem with one side. I removed the mirror and found the ring crushed. Also, make sure you use the plastic tool supplied.
cmac is offline   Reply With Quote
Mirror vibration reduction BRG Twins Talk 5 07-14-2009 04:18 PM
laminar lip , mirror vibration snekeptp Sprint Forum 0 03-28-2009 02:56 PM
bar end mirror vibration jfenton Twins Technical Talk 8 09-05-2007 07:30 PM
Sprint ST Mirror Vibration bradleyd Sprint Forum 25 02-20-2007 11:23 AM
Right Mirror Vibration bosoxrider Twins Talk 2 08-31-2005 12:16 PM
