Sometimes my Speedy doesn't want to go into 1st... - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.com
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 09-17-2009, 08:42 PM   #1 (permalink)
Fenian's Avatar
More and more frequently my '09 Speedy won't shift into 1st from neutral, in other words I'll kick the lever down to go into first from neutral but the shift lever/pedal seems stuck. Several times now I have had to grab the clutch with my right hand and reach down and push the shift lever down with my left hand to go into 1st.
This happens usually when I've been out for a few minutes and I'm at a light or whatever and have put the bike into neutral to rest my hands for a minute.
I'm a new owner/rider and I don't want to kick the lever too hard at this point. Does this sound like some sort of adjustment issue to you guys? I had a look at the shift lever linkage and all seems tight.
Thoughts?
Fenian is offline   Reply With Quote
Old 09-17-2009, 10:15 PM   #2 (permalink)
Favourite Bike: Speedmaster
Clutch adjustment? Try turning the barrel adjuster out a turn or two and see if it's any better.
RonL is offline   Reply With Quote
Old 09-18-2009, 02:08 AM   #3 (permalink)
MercKing's Avatar
I'll have the same problem every great once and a while. If I roll the bike forward and back a bit it'll shift no problem. Happens to me mainly when I'm first starting her up though, which is prolly normal. I came from a honda which is always a pain to get in and out of netural
MercKing is offline   Reply With Quote
Old 09-18-2009, 04:38 AM   #4 (permalink)
Favourite Bike: Triumph Speedmaster 09
Jonsun's Avatar
Other Motorcycle: Triumph Speed Triple 1050
This has happened on both my bikes... I kick into neutral release the clutch then back on the clutch and kick into first... works for me
Jonsun is offline   Reply With Quote
Old 09-18-2009, 05:31 PM   #5 (permalink)
Agree. Sometimes mine will stay in second. If I release the clutch to the point where it starts to grab, then back on the clutch, it will drop into first.
'09 Speedy-19t front sprocket, BC Bomber Pipes,
Progressive Front Springs, Centerstand, 2" risers.
Pending-418HD Progressive rear shocks, ARK.
me1.0 is offline   Reply With Quote
Old 09-18-2009, 09:15 PM   #6 (permalink)
Favourite Bike: 2010 Thunderbird
stuntgroom42's Avatar
Other Motorcycle: No other bike needed
I have the same thing. I just slowly let the clutch out till I feel it release then re-engage and continue downshifting. Its usually after I stop at a light in 4 or so and I am stationary
stuntgroom42 is offline   Reply With Quote
Old 09-22-2009, 12:02 AM   #7 (permalink)
Favourite Bike: 2009 Bonneville America
TriumphLance's Avatar
Other Motorcycle: 2011 Harley Street Bob
The same for me. I'll usually notice that the neutral light is on, but I seem to be as far down on the shift lever that I can be. So, I let out on the clutch a bit, pull it back in, and then it will shift down to first. Pretty rare occurrence, and always when I am stopped at a light.
TriumphLance is offline   Reply With Quote
Old 09-22-2009, 08:58 PM   #8 (permalink)
Favourite Bike: mine
boofhead's Avatar
Sounds like cable adjustment only
Worth a check
what goes round comes round
boofhead is offline   Reply With Quote
Old 09-30-2009, 10:53 PM   #9 (permalink)
Fenian's Avatar
I tried releasing the clutch and pulling it back in, seems to work every time. So simple, why didn't I think of this???
Thanks to all who replied!
If your speedy was a dog, what would it be? skygodmatt Speed Triple Forum 14 07-08-2008 12:16 AM
A pic of my new speedy!!! bikersnoopy Speed Triple Forum 15 05-07-2007 04:28 PM
Whose Speedy was it? nsb748 Speed Triple Forum 0 03-28-2007 07:41 PM
Speedy down! EasyWheelie Speed Triple Forum 15 03-22-2007 10:06 PM
Pic of my Speedy(try #2) Spanky Twins Talk 9 06-07-2006 05:08 PM
