Tach Problem - Triumph Forum: Triumph Rat Motorcycle Forums
Cruisers - America, Speedmaster Cruiser chat for America and Speedmasters
Old 09-15-2009, 12:23 PM   #1 (permalink)
Tach Problem
After riding my tack doesn't reset to zero. The next time I ride it works but at a higher rpm. If it was reading 1k off then it reads 1k above normal rpm. From the sound I can tell it isn't running at such a high rpm. I've had it read as much as 5k over. To reset it i leave the key on and drain the voltage from the tack system by turning the kill switch off and on.
Now for the question. Any ideas what causes this?
I rechecked wires for connection and ground but came up empty.
Romadhusker is offline   Reply With Quote
Old 09-15-2009, 12:29 PM   #2 (permalink)
Favourite Bike: Speedmaster
This has been mentioned several times on this forum and others.
You can try a search, but I don't think anybody's repaired theirs. The only fix I know is have the dealer replace it. Seems it's the new ones that are glitching.
RonL is offline   Reply With Quote
Old 09-16-2009, 04:43 PM   #3 (permalink)
Ru55boy's Avatar
Yeah mine's done that from new (bought in May 09).
The dealer said they will replace it under warranty, I just haven't got around to getting it done.
Easiest way to reset....
Turn the ignition on, turn off - needle drops by 500rpm, turn back on, turn off, etc. - Much better than leaving switched on.
Ru55boy is offline   Reply With Quote
Old 09-16-2009, 05:59 PM   #4 (permalink)
Gidders's Avatar
Other Motorcycle: KTM 300 EXC
Mine is stuck at 1000. I am waiting on a replacement under warranty.
2009 Speedmaster
Gidders is offline   Reply With Quote
Old 09-17-2009, 01:23 AM   #5 (permalink)
Favourite Bike: 2009 Bonneville America
TriumphLance's Avatar
Other Motorcycle: 2011 Harley Street Bob
Exact same thing happened to me - I am having it replaced this weekend. The workaround is to flick the kill switch, as noted in a previous post. My dealer suggested doing that before you start up, rather than right after you stop the engine, as the computer saves engine info from the ride, and doing it right after you stop the engine clears that info.
TriumphLance is offline   Reply With Quote
Old 09-17-2009, 02:27 AM   #6 (permalink)
Gidders's Avatar
I wonder when Triumph will put out a recall on the tacho. Chased my dealer up as still waiting for replacement. He reckons he has 2 others waiting.
2009 Speedmaster
Old 09-17-2009, 09:52 AM   #7 (permalink)
I was lucky then. When I took mine in, they were going to have to order a new tach. I'd have to wait a couple weeks, then go back to get it replaced. The gal looked around and they had a new "accessory" tach on a shelf and just used that one and figured when the replacement came in, they'd sell that one as the accessory. Saved me a trip and it was fixed right away. Kudos to Triumph Detroit! :
Floating tach problem -- or is it normal? Eliezer Twins Technical Talk 4 08-01-2009 12:11 AM
To Tach or not to Tach (Scrambler) TCBLF Twins Technical Talk 14 04-28-2008 01:22 PM
Tach Problem jm06bonnie Twins Technical Talk 18 04-25-2008 08:48 PM
Tach help? 3rd gear @ 35mph What's the tach read? JMart121 Twins Technical Talk 4 06-25-2006 06:56 PM
'97 T-Bird Tach problem WildBill Hinckley Classic Triples 5 10-24-2005 07:46 AM
